Antec troubles - need advice
  • lionclaw
    • Apr 2007
    I've got 3 antec power supplies that are completely useless to me right now, and I'm trying to decide if I should RMA them.
    First is a Neo HE 500W. It apparently isn't compatible with Intel's 965 chipset, and I've got to send it back in to get one with an updated firmware that is compatible.
    The other two are SP-500 models.
    One is making a high pitched squeeling noise, even when the PC is off. It's causing my speakers to make all sorts of pops and squeeks when I play sound on the PC.
    The second will work all the way up until xp or vista (both do the same thing) is almost all the way booted, then the PC shuts down.
    If you guys think recapping the SP-500 units would be a better use of my time, then I might go that way. It's frustrating that I'm going to have to pay to RMA these things.
    In the meantime I'm running on an SP-350, but it can't really handle the load of 6 hard drives, 2 dvd drives, and a 7900gt card. It wouldn't even boot until I disconnected one of the hard drives.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Antec troubles - need advice
    How old are your PSu`s?
    If they are older then one year, i think recapping would be cheaper (if you already have soldering equipment and never mind the time) and a fix that would last a long time.
    But if there are other quirks not cap related, then i would go the RMA route.
    But even then, i would recap at least the SP models.
    • Tom41
      • Oct 2005
      • 336
      • England
      Look through the vents at the back of the PSU, and the cooling fan vent. If you can actually see burst capacitors in there (it might help to use a flashlight to illuminate it), and it's still under warranty, returning or RMAing would be the best option. If it's more than a year old, and/or is out of warranty, it's probably best just to recap yourself.
      You know there's something wrong when you open your PC and it has vented Rubycons...
      • bgavin
        • Jan 2007
        • 1355
        RMA them no matter what. Make Antec step up and own those pieces of shit. Sooner or later they will smarten up and stop using those Fuhjyyu (pronounced: fuhkyoo) crap-caps.
        [ edit ]
        They honor RMA on mine, even thought out of warranty. Tell 'em the caps are bulged and leaking.
        • Oklahoma Wolf
          • Dec 2005
          • 353
          I'd forget the warranty and recap the Smartpowers... odds are pretty good one or more caps are gone. The SP2's were even more susceptible to cooked Fuhjyyus than most of Antec's other CWT built models.
          • fabricator
            • Apr 2007
            • 8
            I had to RMA a smart power 500W recently, not only did it whistle like yours, but both the 5V and 5VSB rails are shot too. Taking a month for Antec to return something to replace it as all of Australia is out of replacement units.
            My own true power-550 has been modded several times to fix things like the fan control mosfet blowing after a cable short.
            • eccerr0r
              It's 2025: do you know where your 5¼" floppy drives are?
              by eccerr0r
              Oh wow.
              As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
              Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
              Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
              Weird. Seems the PC drive is having trouble clamping...
              07-07-2025, 12:49 AM
            • eccerr0r
              failing hard drives after sitting for years...
              by eccerr0r
              With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
              Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
              Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
              03-02-2023, 10:33 AM
            • abajor
              Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
              by abajor
              I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
              I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
              The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
              Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
              04-23-2024, 11:43 PM
            • Borse2008
              Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
              by Borse2008
              Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
              I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
              • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
              • There’s
              07-15-2025, 04:55 AM
            • Green Probe
              Mosfet Advice
              by Green Probe
              Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
              05-22-2025, 10:49 AM
