T3D 21 - zener diode?
  • jm1234
    • Jan 2024
    • 61
    • Slovakia
    I'm looking at the power source module of my Panasonic plasma TV TX-P42ST50. The TV goes into suspended state almost immediately and keeps flashing 6 times.
    That zener diode is marked on the board with the diode sign (D204), that much I know. It seems to be open completely in both directions and its legs seem dark, as if it suffered some heat.
    I'm having trouble finding a replacement. Does 21 stand for 21V?
    The only other clue I have it is connected across 2 of the legs of a transformer (primary side).
    Any idea how to find a replacement?
    Click image for larger version  Name:	Screenshot 2024-04-14 203936.png Views:	0 Size:	212.8 KB ID:	3252836
  • jm1234
    • Jan 2024
    • 61
    • Slovakia
    I went ahead, bought 22V 5W zener, replaced it and the TV doesn't even try to power on now. I removed it again and we're back to what it was (6 led flushes and turns off). So burnt zener (or none) seems to work better.
    • CapLeaker
      Leaking Member
      • 8146
      Not seeing any markings of the diode, I think it is something like a 1.5KE200CA which is a BIdirectional TVS protection diode. It being open on both ends, this is correct and not a failure. Basically 2 diodes opposing each other in one package.
      If that diode sits across the primary it’s not 21V. Hard to tell with no pictures.
      • jm1234
        • Jan 2024
        • 61
        • Slovakia
        Oh that would make sense, learning something new every day. It seems I got to know about components just enough to cause problems :-).
        Anyhow, the markings are in the topic name: T3D 21 (with the digit 1 underscored if that makes any difference). The original diode has dark discoloration on its legs, as if it suffered some heat.
        I measured the voltage between those 2 transformer legs and my meter shows some 800~900V AC, but it only has 750V range, so not sure how reliable that is (I should've measure that before I ordered that zener diode). That value doesn't make much sense to me, as I tried to follow the circuit visually and it seems the transformer is fed almost directly from a bridge rectifier that produces 330V DC (I measured). All in all, more questions than answers.
        Still it seems that TVS diode is not the culprit here, so I might as well put it back there.
        • CapLeaker
          Leaking Member
          • 8146
          ??? Huh? 800 to 900VAC? I don’t think so. Not sure what’s going on with your DMM.
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
            by sam_sam_sam
            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
            I bought this from an eBay seller but unfortunately they only had one
            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
            I bought three of from them to also make battery packs with this output power limit in mind
            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
            04-23-2025, 05:50 AM
          • nev1001
            What zener diode might fix the sound on Maestro Mayhem gaming chair?
            by nev1001
            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
            I think an issue could be a zener diode (or capacitor) which has shorted out.
            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
            04-17-2025, 05:09 PM
          • Vincenzo2
            Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
            by Vincenzo2
            My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
            Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
            I put some pictures here to show that it is labeled "M7"....
            09-07-2023, 07:43 PM
          • hobostove
            Corsair RM1000e - Help identify 5VSB Zener diode
            by hobostove
            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
            There's a 22ohm resistor that's melted and open, but it still has the bands.
            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
            It looks like the diode connects the source and drain of a TNY284...
            03-27-2025, 02:25 PM
