Electrical arching in Dell PA-4E
  • spleenharvester
    • Mar 2010
    • 902
    So I bought a new dock with a genuine Dell PA-4E.
    It powers everything no problem but it's making some odd noises, a sort of scratching/arching.
    Is this something to worry about? It's not loud, I can only just hear it from where I am sitting.
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • mockingbird
    • Dec 2008
    • 5484
    Re: Electrical arching in Dell PA-4E
    Odd that it would do that given that the 4Es are relatively new adapters... Odd unless you consider that whoever made these may have sourced off brand caps... Sounds like one of the caps has dried up... I would definately open it up and have a look inside.
    • spleenharvester
      • Mar 2010
      • 902
      Seems okay now, when it warmed up the noise stopped. It was still a bit cold as it had not long been posted, there was no condensation on the outside but maybe there was some inside.
      Cheers!
      • spleenharvester
        • Mar 2010
        • 902
        Arching sound is back. Thing still puts out power fine. Is there any chance there is electrical glue that is shorting or something?
        • mockingbird
          • Dec 2008
          • 5484
          Crack that thing open and post pics.
          Use a dremel tool with a cutting disc plus a wade flat tip screwdriver. Make sure not to cut too deep or else you might inadvertently damage parts inside.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Asxetos21
            Dell Latitude 5511 audible electrical noise
            by Asxetos21
            I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
            The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
            Any advise on how to narrow it down?
            The schematic is available here:
            Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
            03-03-2025, 09:53 AM
          • F R 2568
            Dell Latitude 5420 does not start (no post) need help to find the reason why
            by F R 2568
            Hello all,
            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
            If the laptop is only connected to the AC adapter (battery removed):
            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
            The power/battery...
            01-08-2025, 05:45 AM
          • diamon
            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
            by diamon
            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
            Pictures of these boards:
            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
            Dell...
            02-28-2024, 12:51 PM
          • lalle-
            Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
            by lalle-
            Hello!
            I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
            [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
            I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
            The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
            I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
            08-11-2024, 02:01 PM
