How to troubleshoot dead power brick
  • mmartell
    • Oct 2013
    • 3189
    I have an adjustable power supply having a selectable voltage from 15v to 24v. It was sold as a universal soundbar power supply.
    It has been outdoors in the elements powering a set of outdoor bluetooth rock speakers until recently when it stopped working. (ya ya I know...)
    I opened it and it looks like there was some liquid ingress but I can't find any shorted silicon and the fuse is not blown. I measure about 160v dc after the bridge rectifier but nothing at the main cap. I suspect the power ic is not running. Obviously there is no voltage on the secondary either.
    How would I go about determining if the power ic has failed or what would be my next thing to look at ?
  • CapLeaker
    Leaking Member
    • 7982
    hmm... I guess you know the drill!
      • Jul 2011
      • 6023
      I second this idea and thought
      • mmartell
        • Oct 2013
        • 3189
        I'm not asking for specifics more general theory. The unit has two large heatsinks covering the components only the back surface mount stuff is visible currently.
        • CapLeaker
          Leaking Member
          • 7982
          Probably something is open in the primary. Make sure the secondary isn’t shorted.
          • mmartell
            • Oct 2013
            • 3189
            I have about 8.5v on the startup pin of the power ic which should be enough to start it but only 3.7v on the run pin which isn't enough. Maybe high esr on one of the caps in that circuit going to take off the hot side heatsink tomorrow.
            • CapLeaker
              Leaking Member
              • 7982
              But you got nothing nothing at all on the main cap and that’s your problem. You need to see the 160VDC not only on the bridge rectifier, they need to be present at the main filter cap on the primary too.
              • mmartell
                • Oct 2013
                • 3189
                But you got nothing nothing at all on the main cap and that's your problem. You need to see the 160VDC not only on the bridge rectifier, they need to be present at the main filter cap on the primary too.
                Ya scratch what I said about the main filter cap since when I measured that the mosfet was pulled off the board with the large heatsink... I had 170v on the main filter cap with it reassembled.
                But I'm looking at the startup section and there is something looking like a tantalum cap (but bigger?) labelled "RT" any idea what that refers to ?
                • mmartell
                  • Oct 2013
                  • 3189
                  Here are some pics the component in question is in the third pic just above the "4" in 400 in the middle of the main filter cap.
                  • прямо
                    • Sep 2022
                    • 261
                    • Indonesia
                    Sensor thermistor maybe? does it look like this picture?
                    Hard to see from your photo because the lighting is inadequate.
                      • Jul 2011
                      • 6023
                      There seems to be some issue with the right hand side of back side of the board there seems to be a lot of flux residue that needs to be removed and you need to look very closely and carefully and each soldering joint I would highly recommend that you put the soldering iron on each one of those soldering joints where all that flux residue becomes this section of this board the soldering joint look questionable at best
                      I would recommend using flux remover or the right type of alcohol to remove the the flux off of the board if you decide to board wash method make sure that the board is completely dry before applying power to the board
                      • CapLeaker
                        Leaking Member
                        • 7982
                        A lot of oxidized solder, exposed traces etc. Make sure the traces are good. Hard to tell what that component is in the picture… I buess a thermal resistor and it has to be good, since you did get 170V into the main filter cap. Look at the components and traces between the FET and 8pin IC PWM
                        • petehall347
                          • Jan 2015
                          • 4423
                          • United Kingdom
                          do you have frequency on your meter ?
                          • mmartell
                            • Oct 2013
                            • 3189
                            Yes
                            • mmartell
                              • Oct 2013
                              • 3189
                              That is from me removing the heatsink the first time.
                              The joints are all good.
                              • mmartell
                                • Oct 2013
                                • 3189
                                I've ohm'd out these traces and they're ok even though they look bad and are exposed.
                                I will take care of that if I repair it and decide to put it back into service.
                                And yes it looks like the picture above thanks for confirming it is working.
                                • CapLeaker
                                  Leaking Member
                                  • 7982
                                  O.k. Now check the two small caps next to the heat sink and that 8 pin IC.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Already checked the caps with an esr tester and both are under 2 ohms iirc ? How do I test the 8 pin ? Its an OB2269CP
                                    • CapLeaker
                                      Leaking Member
                                      • 7982
                                      mmartell
                                      Measure the DC voltage on each pin of the OB2269 and note it down. Download the spec sheet and then let's see what gives. Could be very well the PWM is toast and doesn't wanna do anything. And before I foget it… take some 99% IPA or Acetone and Clan of the bottom of the PCB.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        mmartell
                                        Sorry I was just looking at this again and came back to say I was measuring resistance between gate and source of the mosfet at about 32 ohms so I took it out and measured the pads instead and was the same. After removing the power ic those same pads measure 10k.
                                        Does that indicate a problem with the ic or is that expected ? If it's normal I'll reassemble and take the voltage readings on the pins of the ic. Thanks.
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
