800W PC PSU by Corsair with fluctuating 5V
  • jackster
    • Nov 2021
    • 12
    • Finland
    So I have an old 800W ATX PSU which works otherwise but the 5V rail fluctuates between 4.5V and 5.1V even with no load. Under load the fluctuation seems to be the same, at least with one mechanical hard drive connected.
    3.3V and 12V are fine.
    All electrolytic caps look ok visually, but should one still start the repair/diagnosis by replacing all relevant caps?
  • temyth
    • Jan 2024
    • 45
    • Brazil
    is it DC-DC? i would check the cap's
    • jackster
      • Nov 2021
      • 12
      • Finland
      Each rail is independently regulated. The two 16V 2200uF electrolytic caps in the 5V rail look good on the top, but it's very hard/almost impossible to see the rest of them due to so many cables and other components cramped right next to them.
      But just in case I have already ordered replacement caps.
      • temyth
        • Jan 2024
        • 45
        • Brazil
        there are regulation modules for each reails that you can put apart of the main PCB? also, would you please share the specific model of the PSU?
        • jackster
          • Nov 2021
          • 12
          • Finland
          No there are not separate regulation modules AFAIK but there are separate chokes for each rail (3 in total). And oh yes sorry the exact model is Corsair Gaming Series GS800, techpowerup has good pictures of it: https://www.techpowerup.com/review/corsair-gs800/4.html
          • temyth
            • Jan 2024
            • 45
            • Brazil
            alright, so the PSU it's not DC-DC and the voltage is controlled by switching the primary mosfets. Try checking the voltage comparator in the line that its unstable, they get bad pretty often. They are commonly TL431A or other kind of comparator. In this PSU it may be in a SMD version.
            • jackster
              • Nov 2021
              • 12
              • Finland
              I replaced the two 16V 2200uF electrolytic caps in the 5V rail today but it didn't help so the problem is elsewhere.
              So I followed your suggestion and went searching for the voltage comparator of +5V and I think I found it, it's a Texas Instruments TL431AC. It seems to be connected to the +5V rail via these two resistors:
              Now I just need to wait another month for the replacement comparators to arrive from aliexpress 😅
                • 31086
                3.3v and 5v are usually on the same transformer,
                so if it is and the 3.3v is fine i would look at the 5v output rectifier
                • jackster
                  • Nov 2021
                  • 12
                  • Finland
                  Thank you for the suggestion, I think it looks like 3.3V and 5V are on the same transformer. And the 5V output rectifier seems to be this one (STPS3045CW, circled with red colour):
                  Click image for larger version  Name:	20240220_212935.jpg Views:	0 Size:	2.76 MB ID:	3220517
                  Might as well order some of those rectifiers just in case, the voltage comparators were dirt cheap.
                  • прямо
                    • Sep 2022
                    • 261
                    • Indonesia
                    That could be for the 5v standby.
                    You still have 3 pairs of those dual rectifiers, which I believe one pair is for 3.3v, another pair is for 5v and last pair is for 12v.
                    • Nagy Daniel
                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                      by Nagy Daniel
                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                      So, I generated a table with AI so I can...
                      03-04-2025, 08:24 AM
                    • bimole
                      Weird behavior on 3.3V rail of a CORSAIR CX600
                      by bimole
                      A colleague gave me an apparently ill CORSAIR CX600.
                      He told me that he heard a banging noise, and smelt the magic smoke.
                      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                      It's another story on the 3.3V rail...
                      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                      02-13-2025, 04:49 AM
                    • Novgorod
                      Corsair SF450 PSU: can faulty -12V rail be removed?
                      by Novgorod
                      I have a Corsair SF450 SFX power supply with slight water damage. 5VSB is present and it turns on via the ATX PS_ON pin, but immediately goes into protection mode (relais clicks on and off). During the brief moment before protection kicks in, all power rails are present except the -12V rail, which also went low resistance (24 ohm). I don't know if protection mode is triggered by over current on -12V due to the low resistance (the current limit is only 0.36A on that rail according to spec) or simply because the voltage is not present. I removed the IC generating the -12V (54231 buck converter)...
                      08-21-2024, 06:38 PM
                    • Cemal Odabasioglu
                      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                      by Cemal Odabasioglu
                      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                      Observations...
                      01-14-2025, 03:54 PM
                    • parakeet
                      Corsair CX500 ATX PSU|Works under some/no load, but not in motherboard
                      by parakeet
                      Hello.
                      I'm trying to fix a Corsair CX500 ATX Power supply. It works fine with no load or with a couple of devices connected but turns on for only 0.5s in the motherboard. I've tested the motherboard with a different, lower wattage rating PSU and it works fine, so I know that isn't the issue.
                      3 Different ways I've tested it:
                      1. Switch on with no load: All voltages good except -12v (-10.8)
                      2. Switch on with CD drive and HDD connected: All voltages good, peripherals working
                      3. Switch on with 24 Pin connected to motherboard: Turns on, then off after...
                      06-11-2023, 11:26 AM
