Chieftec CFT-650-14C
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, i got PSU chieftec cft-650-14c. Problem is thet 5V rail is to low. (not 5VSB)
    on my Manhattan PSU tester say that +5V LOW. I replace all caps for 5V rail but still +5 LOW.
    any idea?
    ...the quieter you become the more you are able to hear...
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: Chieftec CFT-650-14C
    i check it, it is 3.56V
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Try it with some real load.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        no still LL +5V
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Originally posted by rtstorm
          no still LL +5V
          You put a load on the 12V rail? If not, do so and see what the 5V rail does.
          Muh-soggy-knee
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • lefetylorant
            Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
            by lefetylorant
            Hello Everyone,
            Long story short, I got this unit for very cheap.
            I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
            I've performed some measurements:
            - 20V rail perfectly...
            09-14-2023, 05:05 AM
          • bimole
            Weird behavior on 3.3V rail of a CORSAIR CX600
            by bimole
            A colleague gave me an apparently ill CORSAIR CX600.
            He told me that he heard a banging noise, and smelt the magic smoke.
            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
            It's another story on the 3.3V rail...
            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
            02-13-2025, 04:49 AM
            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
            by momaka
            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
            http://www.rmac.kingwin.com/products.../abt_650MM.asp
            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
            What mostly drew me into buying it is its 2x PCI-E power connectors...
            03-29-2022, 11:34 PM
