QJE PS3010 Switching Power Supply schematic
  • Mobiletech-AUS
    • Dec 2023
    Does anyone have a schematic diagram of a QJE PS3010? I suspect a 1000uF across the DC output as initially it works then after a minute shuts down. There is a residual current drain with nothing connected. Appreciate if someone can help as I dont want to bin the PS.
  • temyth
    • Jan 2024
    • 45
    • Brazil
    i've noted that this same power supply has another brands named on it, like ICEL here in Brazil. the real thing is to know who is the real manufacturer to get the right schematic. I didn't find any schematic in the internet about this PSU. Does it works perfectly before it shuts down?
      • 31163
      check the output diodes
        03-31-2024, 02:12 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        07-01-2024, 06:34 AM
        DVR camera recorder switching power supply capacitor failure really
        These cheap non brand capacitors at it again
        Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
        Well at least I have the cameras back on line I to try the...
        01-22-2022, 06:28 PM
        After all of...
        07-13-2024, 08:14 PM
