Power Suply Led Driver Repair Problem
  • rodrigo.bernardo
    • Jan 2024
    • 5
    • Portugal
    I am trying to repair a faulty power suplly for a LED Light.
    I measure 0 V on the output so LED dont light up, however in the input (out of rectifier), I have 60 V, so the problem must be in the middle.
    Capacitors seems to be good condition, diode is also good (I tested). No burn signals elsewhere.
    I attached the pcb board and a shcematic that I draw from observing the PCB. Note that there is an IC with the letters "BVYDLA" (I think its that)... its the only thing I found written on IC.
    I cant find datasheets of this PCB.
    Thanks for everyones help. Every tip I can get to found the problem or to identify the IC is welcome.
    • 31259
    check the input to the rectifier.
    you should have 230v ac going in and about 340v dc coming out.
    if it was an overload the rectifier would explode or the fuse would blow - so it's not a problem after the rectifier.
    it's the rectifier or something before it - maybe the fuseable resistor in heatshrink is bad
    • rodrigo.bernardo
      rodrigo.bernardo commented
      Editing a comment
      Sorry, on the output of rectifier I have also 26 V when measuring in DC mode. On the input of rectifier I measure 26 V. If you look at one of the photos, you can see that between the two oxide varistors, there is a transformer that stepsdown the input AC voltage. The fuse resistor its fine. On the input of transformer I measure 230 V AC.
      Thanks for your reply
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    "If you look at one of the photos, you can see that between the two oxide varistors, there is a transformer that stepsdown the input AC voltage."
    That is an inductor, it is just for common mode interference reduction, it does not change the AC voltage.
    Do you really have 230VAC before that component and then 26VAC after it?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      Hmm... Something is fishy with this measurement. Verify your AC measurement going to the bridge rectifier and your DC measurement leaving the bridge rectifier. Being both the same voltage, I am not buying it.
      I suggest you check continuity on each leg from the AC side to the bridge rectifier. If there is an open, it will show.
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • adom
        fingerprint driver problem after bios dump. EliteBook 840 G7
        by adom
        Hi, everyone
        i changed the serial number with the program lbe++ (dump cleaner) after the installation i had to find out that the fingerprint driver is missing. I have tried everything but without success (windows update, hp driver update)
        How can I fix the problem?
        HP EliteBook 840 G7...
        05-24-2022, 10:21 AM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • Gibon378
        Problem with stopping audio and video for no reason
        by Gibon378
        PC Specs:
        • CPU: Ryzen 5 1600
        • GPU: GTX 1080 Palit JetStream
        • MOBO: ASRock ab350 PRO4
        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
        • PSU: XFX 650W (don't remember what model)
        • OS SSD: ADATA SP920
        • OS: Windows 10 21H2
        Problem description:
        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
        11-19-2022, 09:41 AM
      • howardc64
        QN75QN85BAFXZA no backlight
        by howardc64
        2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
        PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
        07-03-2025, 05:08 PM
