looking for programming software for board ETON.ET866 1302.2Z2
  • BOSCHNJAK
    • Dec 2023
    • Bosnia and Herzegovina
    I am looking for programming software for board ETON.ET866 1302.2Z2. This PCB is built into the Switching Power Supply from ACBEL model FSA011 and I need information on how to program that PCB, On the board there is a small connector with 5 pins.
    I need a programmer or emulator to access this board and adjust the voltage from 12.2 volt DC to 13.8 volt DC.
    Can anyone help? Pictures attached.
  • BOSCHNJAK
    • Dec 2023
      • 31246
      are you sure the header isnt just for programming the pic chip?
      • BOSCHNJAK
        • Dec 2023
        There is 2 small 5 pin connectors on this PCB, I do not know nothing about, but there PIC16F chip on board. I suppose this chip is IN CHARGE for kind of control... Need information where to find cable or adapter cable to connect this connectors via serial or USB interface to MPLAB software to try to read data. All of this is my guessing. Try and tray. So if you know what kind of serial or USB cable can help, or other tools that I can connect, send info. Thank you in advance.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          After all of...
          07-13-2024, 08:14 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • gabri2211
          external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
          by gabri2211
          Hi to all 😎
          I'm looking for any useful information to repair this interface (I have attached the image).
          On this board I read E3215-1215A_4D.
          This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
          If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
          in particular...
          11-12-2024, 08:08 PM
