KDM 480W PSU upgrade succes! (opinions?)
  • bauto601
    • Sep 2012
    • 102
    • Netherlands
    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
    A "nice" YoungYear unit? - Badcaps
    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish. I mean, they even included an input voltage selector switch 🤨
    Click image for larger version  Name:	compactpsu.jpg Views:	0 Size:	161.9 KB ID:	3168444Click image for larger version  Name:	psulabel.jpg Views:	0 Size:	211.7 KB ID:	3168445
    Opening up the unit made clear it wasn't a decent Active-PFC unit and that it wasn't going to hit that 24A spec, 200W in total would've probably been a more realistic expectation...
    Click image for larger version  Name:	fetch?id=2047644.jpg Views:	0 Size:	505.5 KB ID:	3168446Click image for larger version  Name:	fetch?id=2047645.jpg Views:	0 Size:	668.2 KB ID:	3168447Click image for larger version  Name:	fetch?id=2047646.jpg Views:	0 Size:	559.7 KB ID:	3168448Click image for larger version  Name:	fetch?id=2047647.jpg Views:	0 Size:	694.3 KB ID:	3168449
    Low and behold, a very basic and compactly built half-bridge unit... Just a mediocre one. There hasn't been any extreme corner cutting when compared to the real gutless wonders, but definitely not powerful in any way. The transformer and output toroid are pretty small and the PFC is nowhere to be found. Some noteable things were the partially present input filtering (yay), low profile transformer (EI33 but shorter), the small output toroid and the 3.3V rail which is actually tapped from the 5V rail and regulated with a mosfet.
    The last couple of years this PSU was one of my side projects which sometimes got a bit of attention. The modded YoungYear unit was lasting better than expected so the urge to complete this project disappeared for a bit. But recently i acquired an Oculus Quest 3 VR system which required a bit more graphical horsepower from my PC. So here i go, ordering a Radeon RX6800 GPU while being fully aware that my current YoungYear unit can't handle it 😅 All hopes are on this KDM unit now 🤞 A couple of years ago i did make the first round of upgrades and posted the results in the hall of shame thread:
    https://www.badcaps.net/forum/troubl...75#post1423575
    To keep thing simple i'll just post the end result here. Last week i gave it a final round of upgrades, hoping it would do ~300W. It got upgraded quite extensively, the transistors, 12v rectifier, main transformer, output toroidal and heatsinks were upgraded. The whole PSU got Teapo-fied except for the primaries. Passive PFC was also added as well as temperature-based fan control.
    Click image for larger version  Name:	PSUPCB.jpg Views:	0 Size:	232.4 KB ID:	3168452Click image for larger version  Name:	psuoverview.jpg Views:	0 Size:	254.3 KB ID:	3168453Click image for larger version  Name:	psusecondary.jpg Views:	0 Size:	274.7 KB ID:	3168454Click image for larger version  Name:	psumisc.jpg Views:	0 Size:	349.3 KB ID:	3168455Click image for larger version  Name:	psuprimary.jpg Views:	0 Size:	218.1 KB ID:	3168456
    Primary:
    NO PFC -> Passive PFC
    2x Y capacitor
    NO X capacitor -> added X capacitor
    1x common mode choke -> 1x better wound common mode choke
    2x 2.5A diode + 2x 4A diode -> KBL406 rectifier bridge
    2x 470uF 200V Ltec primary caps
    2x 13007 primary transistors -> 2x D304X primary transistors (still TO220)
    1x SVD2N60F mosfet
    Swapped primary heatsink
    Middleware:
    ERL33 low-profile transformer -> ERL35 full-height transformer (swapped the primary snubber circuit with it)
    SC6105 switching controller
    Added temperature-based fan control
    Secondary:
    12V: MOSPEC F16C20C 16A TO220 Fast Recovery -> DSSK 40-008B 40A 80V TO-247 Schottky
    5V: MOSPEC S30D45CS 30A TO247 Schottky
    3.3V: Advanced Power AP40N03GP 40A mosfet (tapped from 5V)
    Tiny output toroid -> Way bigger output toroid (with more efficient green/blue core and thicker windings)
    Swapped secondary heatsink (modified a bit to make the larger output toroid fit)
    Output Filtering:
    12V: 1x 1000µF 16V ChengX, PI Coil -> 2x 1500µF 16V Teapo SY, PI Coil
    5V: 2x 1000µF 10V ChengX, PI Coil -> 2x 2200µF 6.3V Teapo SC, PI Coil
    3.3V: 1x 1000µF 10V ChengX, PI Coil -> 1x 2200µF 6.3V Teapo SC, PI Coil
    +5VSB: 1x 470µF 16V ChengX -> 1x 1000µF 6.3V Teapo SY
    -12V: 1x 470µF 16V ChengX, NO PI Coil -> 1x 1500µF 16V Teapo SY, added PI Coil
    -5V: 1x 470µF 16V ChengX, NO PI Coil -> 1x 1000µF 6.3V Teapo SY
    Testing - Power Output:
    A heavily overclocked furnace ...uhh.... Pentium D CPU was used to test the constant power output capability. The test was running for about ~20 minutes to make sure heat-soak wouldn't get me in the end. Using my PR10 power meter (wall power) and a current clamp (output power) i got the following numbers:
    Input power: ~440W (225V, 0.73 PF)
    Output power: ~333W (~76% efficiency, ~24.4A@12V, ~5.2A@5V, ~3.0A@3.3V)
    I used an overclocked Radeon HD6870 for testing it with a bit more transient loading. The Pentium D was downclocked a bit to keep power draw withing reasonable limits. The PSU didn't even flinch at this test while drawing 400~460W from the wall.
    Testing - voltage regulation:
    Voltage regulation seems to be okay-ish, perfectly adequate to power a PC:
    3.3V: ~3.4V
    5V: ~5.3V
    12V: 12.45V unloaded, 12.0V when heavily loaded
    Testing - Output Ripple:
    Output ripple has been tested with the CPU load test whilst drawing about 450W from the wall. The scope shots are a bit noisy but this is most likely caused by the PC system itself, normally these shots are made when using resistive loads or specialized PSU test equipment. But anyway, it's better than nothing....
    12V: ~80mV
    Click image for larger version  Name:	12v ripple 450.jpg Views:	0 Size:	123.3 KB ID:	3168457
    5V: ~35mV
    Click image for larger version  Name:	5V ripple.jpg Views:	0 Size:	110.6 KB ID:	3168458
    3.3V: ~15mV
    Click image for larger version  Name:	3.3V ripple.jpg Views:	0 Size:	106.6 KB ID:	3168459
    Switch Frequency: ~55KHz
Name:	switch frequency.jpg
    Conclusion:
    All-in-all this isn't a bad result i think, especially being able to output ~325W with it's compact design and 470µF primary caps. Ripple ain't that bad either. The components were getting a bit warm though at this power level, i had a temp-probe attached to the secondary heatsink which was reading between 65~70°C. Not shockingly hot but definately indicating that there isn't much wiggling room left. The passive PFC coil is getting a bit toasty though.
    I think it's ready for the real challenge, powering the Radeon RX6800 😁
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Originally posted by bauto601
    And the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish. I mean, they even included an input voltage selector switch
    You seem really dedicated to these old PSU designs, good job!
    Just a small tip: if a PSU really has Active PFC there will not be a voltage selector switch.
    The reason is that the APFC stage boosts the input voltage from whatever it is up to ca 400VDC.
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      Interesting approach to increase a weak power supply by changing the primary caps, primary switching transformer transplanting semiconductors and secondary toroid inductor from a beefier power supply.
      • temyth
        • Jan 2024
        • 45
        • Brazil
        wow, thats a pretty decent upgrade, congrats! i would just update from to-220 to to-247 as it can handle more power. i would put a pair of 13009L (each one haves 30w more than your current d304x, +60w in the total)
