none OEM charger for iPad Pro 12.9
  • paparazzo79
    • Dec 2018
    • 299
    • Bosnia
    Hi guys.I got myself iPad Pro 12.9 2015 but it came with none OEM charger and USB type A to lightning cable.
    May I use it to charge iPad without harm?
    • 31181
    it wont harm your ipad, but be carefull what charger you use.
    ipad's can pull upto 2.5A
    now maybe the cable will restrict that to 1A - but if your not sure then dont try to use a low current phone charger
    that "warp charge 30" is unknown to me - i wonder if they mean you can pull 6A for upto 30 seconds before it gets too hot?
    i wouldnt want to test that theory
      • Jul 2011
      • 6060
      I personally do not trust this type phone charger the quality to me is poor at best and I have seen several failure that I would be scared to use them for anything above 500 milliamperes might alright for this use
      I also find that if use them above 500 milliamperes they run very warm for my comfort and the higher the amperage the warmer they get which is the troubling part for me
      • paparazzo79
        • Dec 2018
        • 299
        • Bosnia
        It's a One Plus Nord charger.
          • Jul 2011
          • 6060
          Dose that really matter if the charger is running really warm on 500 milliamperes in my book it is not a good quality charger in my personal opinion
          I really do not care who made it
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8318
            Charging an iPad on 500mah going to take all day! I think the original chargers were like 3A. These days I have one charger Anker 737 120w and I charge everything on it. iPhone, iPad and a laptop at the same time.
            • paparazzo79
              • Dec 2018
              • 299
              • Bosnia
              But output is 5V and 2A.Where do you see 0.5 A?
              Besides for Li-ion batteries it is always better for health of a battery to charge it with low current.
              fast charging the phones with high current is not good for battery.
              • paparazzo79
                • Dec 2018
                • 299
                • Bosnia
                Is not running warm at all.It's a 5V 2A charger and it charges 10k mAh battery all day long.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8318
                  not quite so true for the iPhone. Got a new iPhone 15 plus. That thing charges super fast on the usb c cable without getting hot. Using an Anker QC3 charger. Wireless charging is cool, but wastes energy compared to plugging a cable in.
                  • GeirAndersen
                    iPad .pcb file collection
                    by GeirAndersen
                    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                    IPAD COLLECTION 1
                    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                    12-09-2024, 09:28 AM
                  • motormayhem
                    Lenovo T460 Only Charges on One Charger
                    by motormayhem
                    Laptop Question
                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                    05-12-2023, 01:46 PM
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
                  • flat-earther
                    how to prevent a connected charger from draining battery when not charging?
                    by flat-earther
                    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                    So the battery is backfeeding the charger and being drained.
                    How can I prevent...
                    08-07-2025, 01:04 PM
                  • flat-earther
                    ASUS X54H laptop thinks it's always charging even with charger unplugged
                    by flat-earther
                    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                    Windows also shows ''Plugged in'' when charger is not connected.
                    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                    If I let battery run out and say it has 3% Windows will...
                    06-24-2025, 09:32 AM
