FSP250-50MSP PSU from MSI Hetis G31 Barebone 250W
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    Re: FSP250-50MSP PSU from MSI Hetis G31 Barebone 250W
    Hi there.
    Had the same issue with this PSU mounted on a Hetis 945-E.
    All my secondary caps are yet good and I noticed that strange behaviour with the power-on led of the mainboard. Found power-good line almost down on small load while solid +5v without load.
    Changed those 2 caps on the pwm board as in post #11 and problem solved. In my case the 1uF was totalized and the 2.2 has 11ohm esr. Don't be lazy and check also the other 16uF and 100uF caps on that tiny board, it's a real pain in the arse to get out and put in.
    I also put some heatshrink tube on the exposed lead of the big resistor next to the board. It's so creepy how it sits a couple of mm to the big heatsink. Probably there's no problem even if it touches it but never say never...
    • MHTSOS
      • Jun 2014
      • 17
      • Greece
      Does anybody know if it's safe to replace the 2 caps that help drive the bases of the transistors with mlc caps? They are located in a very hot area with no cooling from airflow and I guess mlc caps would last much longer. I have done it as an experiment on 2 psus and they seem to work fine under load but I don't have an oscilloscope to compare the waveforms between electrolytic and mlc caps.
      • madura2010
        DAY11AM6E0 hard disk drive and optical disk drive not detected
        by madura2010
        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
        i checked the connectivity of ribbon=good communication with hard and motherboard
        changed hard disk and checked=3f0 error persist
        sata power=+5v available
        Then checked data capacitors=all good
        Then checked data lines path connectivity to pch=all good
        reflashed...
        03-12-2023, 09:09 AM
      • mkdj
        Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
        by mkdj
        Dear all,
        I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
        Here the steps I have taken to fix the laptop:
        - downloaded latest BIOS from Lenovo Website...
        10-18-2025, 03:43 AM
      • Eleways
        Apple Macbook A1707 Hard disk
        by Eleways
        Hi
        I've an Apple macbook A1707 with Hdd defect.
        This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
        My question is:
        Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
        Can i replace with a different one (es 500 gb instead of 250 gb)
        This Macbook has T1 security check.
        Thanks and best regards
        Luca
        02-18-2022, 04:23 AM
      • Zentech
        Laptop Hard Disk Not Recognized By Computer
        by Zentech
        I have a laptop hard drive that I've plugged into different computers and it is not getting recognized. I'm using a usb connector/sata adapter to use it as usb storage, but "Disk Manager" is not giving me the Initialize disk option. I can scan the disk for error, I tried in Windows and Linux with same result. Is this a problem with the hard drive hardware? has anyone repair a hard drive before?...
        04-19-2021, 09:29 AM
      • federalhouse
        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
        by federalhouse
        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
        **Background:**
        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
        **What I've Tried So Far:**
        1. I accessed
        08-01-2024, 07:03 PM
