Bitfenix Whisper 850W - Only 5VStby and PSON
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Hi:
    I am trying to repair this modular ATX PSU. It only has the 5V Standby and PSON enabled (3.33V).
    PSON is delivered by (ST9S429-PG14) in pin4. This chip is a Voltage controller but it doesn't seem to trigger any PWM signal to pass it to primary through coils and "move" the big mosfets. Also next to it there is a EST7618 that it also seems a voltage controller.
    Not sure if in the right direction, but trying to find where PWM signal is generated.
    Green section seems that could be the "PWM section". It's driven by a CM6901 (back side).
    So far:
    - I've checked the 3 opto couplers. They seem ok
    - I've checked the 5 pieces (igbt, shotky......) from the khaki section and they read ok.
    Any recommendation where to focus the analysis?
    Click image for larger version Name:	Word-press-whisperM-overview_08.png Views:	0 Size:	741.0 KB ID:	3154363
    Click image for larger version Name:	20231127_111741.jpg Views:	0 Size:	2.35 MB ID:	3154364 Click image for larger version
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    I am focusing on the green section and the CM6901 chip. These are the readings I am getting when I switch on the PSU
    Pin 1 - 5.35V
    Pin 3 - 6.12V
    Pin 4 - 4.51V
    Pin 5 - 4.45V
    Pin 9 - 2.09V (triangular clock signal)
    Pin 15 - 14.67V
    Pin 16 - 7.5V
    Rest of pins: No voltage
    Pin 7 (CSS) has no voltage.........maybe that's the reason the IC doesn't switch on?
    Anything that might indicate that chip is faulty??? (no pwm readings in pins 11-14)
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      Pin 3 - 6.12V
      Hmm, datasheet says max voltage for pin 3 is 5.5V so you should trace to where is that 6.12V coming from because 0.6V higher than what is allowed indicates an abnomal operation. It could have been the reason that killed the controller IC.
      As for CSS, you can probably try to inject 1.5V to see if that will force the controller to switch on and send out some PWM signals. If it doesn't switch on, then it's probably dead.
      • CapLeaker
        Leaking Member
        • 8352
        Check carefully how this PSU turns on. Measure the outputs and see if you see a blip of voltage and then shuts off. If it does, this sucker has TWO supervisor IC's to look at!
        • ssrkh
          • Jul 2023
          • 12
          • Malaysia
          there must be some ic
          • Francesc V.
            Tempus fugit
            • Nov 2022
            • 231
            • Catalonia
            Hi:
            First of all, thank you for your time and feedback. Thank you for the attached files. I didn't know about this web and it's amazing. So much appreciated. 😀
            (There is no "miliseconds" output when I switch on the PSU). Primary doesn't do the job........
            прямо Thanks for the comment: I injected 2V into pin 7 (CSS) that confirms that CM6901 is working (PWM signal on 13-14 that goes to gates at GP28S50Gs). It's pending to investigate why there is no voltage on that pin. Forcing CM6901 to work has shown that secondary output delivers 12V & -12V (rest of voltages are not present) and the PSU makes "tic-tic" noise due to the two reles that are running to prevent some damage there.
            Also I have discovered that the other PFC controller is not receiving any voltage at pin 11 (CM6500UN)................maybe with current situation there is some mechanism that prevents it and it could be normal.
            Last but not least, I've discovered a shorted N channel MOSFET that I've already removed and asked for replacement (LPW).
            Silly question: Could I just put other N channel MOSFET (I only have A09T) to see whether there is any improvement in the PSU? Or it's better to wait? (see attachments for both items)
            Click image for larger version Name:	20231129_144311.jpg Views:	0 Size:	5.22 MB ID:	3155338
            I see some light there..............maybe it's the train coming. 🤣
            Regards,
            Francesc.
            • прямо
              • Sep 2022
              • 261
              • Indonesia
              Are you sure the PFC controller is not running? because when you forced the first PWM controller (CM6901) to switch on, you did get the 12V secondary output didn't you? and I'm pretty sure if you also force the 2nd PWM controller to switch on, you will get the rest of the secondary voltages (3.3V and 5V)
              EDIT: Or you can check if the primary cap is charged around 400V DC when CM6901 is forced to switch on. If it is, then the PFC is definitely working.
              Are you sure it's shorted? Did you check it out of circuit?
              It may or may not work. 2N7002CK has twice VDS (60V) of the AO3400 VDS (30V) and higher RDS On.
              2N7002 is a pretty generic N-Channel MOSFET. You can probably salvage one off a dead motherboard.
              • Francesc V.
                Tempus fugit
                • Nov 2022
                • 231
                • Catalonia
                Main cap is only charged to 300V.......APFC is not there, yet. We will need to wait when we demand power to the PSU whether cap goes up to 400V.
                Yeap......I started measuring Drain-Source on the PCB getting diode junction, moved from source to gate and back to source and measure didn't changed (this raised an alarm). I removed from the PCB with same result. It's dead. It's twin brother next to the picture is fine (Drain-Source is close to zero when you activate it's gate).
                I had a surprise when I switched on again PSU without the faulty SMD..........I am now having all voltages but no PWR_OK signal. I have the feeling that when I replace with a good LPW, everything will be back to normal. Fingers crossed.
                Other interesting things I've found during analysis......."some chips such us CM6500un are not powered up until you press PSON".
                • CapLeaker
                  Leaking Member
                  • 8352
                  A PFC isnt coming on after the fact. It's gotta be working before current is drawn.
                  • Francesc V.
                    Tempus fugit
                    • Nov 2022
                    • 231
                    • Catalonia
                    I am still on it, but no progress so far.....
                    What could be the reason for having ALL and stable output voltages (but no PWR_OK signal) when "faulty" LPW is not installed on PCB, but when I put a new one (I've changed the whole pair) I only have the standby voltage in the power supply?
                    Things that might be interesting but I guess there's an explanation:
                    - Bottom LPW: I have a diode junction between D-S.........then I switch one probe to gate and go back to D-S having a short...........the expected behaviour for a N-Channel mosfet.
                    - TOP "faulty" LPW: I have a diode junction between D-S.........then I switch one probe to gate and go back to D-S having still a Diode junction. (this lead me initially to thought that mosfet was faulty).
                    I've checked all at component level........but i don't see anything obvious. :-(
                    Thanks in advance for any hint,
                    Francesc.
                    • прямо
                      • Sep 2022
                      • 261
                      • Indonesia
                      I thought PG (POWER GOOD) is from the supervisor IC? and PWR_OK is from the mainboard PCH, to sync up the rest of the mainboard power sequence??
                      • Francesc V.
                        Tempus fugit
                        • Nov 2022
                        • 231
                        • Catalonia
                        Today I had some spare time and I've tried it again. I finally fixed it. The rele wasn't making any noise so I've checked the components near to it. There was a tinny SMD capacitor shorted(C21) and the T4 diode (D5) was open circuit (not shorted but faulty). I replaced both and finally the SMPS came back to life.
                        What a pain in the ass this one.......🤣
                        • piernov
                          Reminder: rules and organization of this section
                          by piernov
                          Activity on this forum has been increasing steadily and the workload for the moderation team as well in order to keep the place clean, so please make an effort to keep it organized.
                          I've been deleting more and more posts that make a mess, so take a minute before posting to make sure you make a proper request/offer.
                          Reminder about the rules and the organization of the "Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals" section.
                          This section and its subsections are about the following classes of devices:
                          • Desktop computers
                          • All-in-one
                          03-31-2023, 06:17 AM
                        • sheffieldyorky
                          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                          by sheffieldyorky
                          Hey there people
                          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                          This is what I tried, but not in any order.
                          Google
                          YouTube
                          BIOS
                          Command Prompt (administrator privileges)
                          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                          10-25-2025, 02:22 AM
                        • piernov
                          by piernov
                          Reminder about the rules and the organization of the "Troubleshooting Laptops, Tablets, and Mobile Devices" section.
                          • Laptops
                          • Phones
                          • Tablets
                          • Other mobile devices
                          03-31-2023, 06:10 AM
                        • stingerchamp
                          Ddr3/ddr4 ram section voltage requirements(working)
                          by stingerchamp
                          Follow this guide to verify voltage at RAM SECTION
                          DDR 3 ram section voltage check list at ram slot
                          DDR3 operating voltage VDD (at coil )= 1.5V PINs 75,76 ram slot
                          VRef_DQ = 0.75 V at PIN 1
                          VTT/Termination voltage= 0.75V PINs 203,204
                          VRef_CA. = 0.75V PIN 126
                          VDD SPD = 3.3V PIN 199
                          SDA data = 3.3V PIN 200
                          SCL clock = 3.3V PIN 202
                          DRAM_RST# = 1.5V PIN 30
                          DDR 3L ram section voltage check list at ram slot
                          DDR3L...
                          12-12-2020, 02:07 AM
                        • nubinator
                          Samsung Q6F edge LED section not working
                          by nubinator
                          Trying to fix Samsung Q6F with dark vertical area and when I unplug motherboard and turn on tv 1 backlight section is not coming on but with LED tester all the sections work. On TV power supply I measure on +side 130v for all sections and on -side I get 55v for all sections except the one not working which is only 5v.
                          How do I tell if problem is PSU or strip? On the LED tester it reads 68v for all sections. I fully expect it to be a bad strip cause the strips and diffuser are so melted and cracked im surprised any LEDS work...
                          10-22-2023, 04:08 AM
