Bad PSU cooler Master M1000 A000 EMBA Need Advice on Caps and Mosfets
  • GreenOne_Mk
    • Dec 2012
    • 13
    • Yugoslavia
    Hi To all members of the badcaps Technical Forum
    Especially to Sticky Topcat from which I get all the info abouth PSU supplyes
    I had purchesed a cooler master m1000 Emba power supply
    and it went dead and i cant figure it out why i guess it was some kind of flictuations in power load or frequency!!!!!!! and it went bad anyway a frend of mine opened it up and found out that mosfets on the heatsink were shorted and output caps 3300 uf caps 16v and 2200uf caps 10 volts were leaked and also 2 vprimary caps on primary side 470uf 270v caps 2 capacitors vere bad he somehow checked the 2 transformers visually and with multimeter and said that they apear ok both visually and with meter so my Question is if the transformers are ok can he somehow repai the psu by replacing bad parts with new ones and also If any member on the forum knows what kind of parts should i bought I mean caps and mosfets
    1. what model of mosfets should I buy model number and make
    2.What series of capacitors should i bought what resistance from nichicon
    or rubycon for primaryes and output caps
    All I knew that the PSU is chaos I\m trying to repair the psu if i can
    I spend a lot of time searching for the right type of caps
    If someone knows from where to buy the mosfets on internet and model please send me lionks
    The bad caps i topic are nichicon or panasonic I belive
    Thank you in advance to all members
  • senz_90
    • Aug 2013
    • 328
    • Indonesia
    Re: Bad PSU cooler Master M1000 A000 EMBA Need Advice on Caps and Mosfets
    Please try to post a picture, and you ask something that I think yourself know, how can we know the values of this mosfet or caps if you didn't describe the details values...we are not Harry Potter man. give the values and this forum member will show you the way..
    "There is no shortcut to be successful. No pain, no gain."
    Best Regards
    Rudi
    Thank You
    • davidebaldini
      ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
      by davidebaldini
      This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
      1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
      01-25-2023, 02:23 PM
    • Uranium-235
      Scythe Fuma 3 or Cooler Master MA620M
      by Uranium-235
      I have a 5900x to replace my 5800x (actually a fair bit of performance difference). It came with the CM. I can't actually find any article of a direct comparison between the two. The Fuma has a Higher TDP but the CM looks to have a more solid build. Fresh AS5 either way.
      Scythe Fuma 3
      100.00%
      1
      0%
      0
      11-01-2025, 02:08 AM
    • Topcat
      Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
      by Topcat
      This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
      ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
      03-12-2022, 10:58 PM
    • anikin73
      Cooler Master 500W atx psu repair. Total cannot start at all
      by anikin73
      I am attempting to repair this. Circuit is quite simple, but i a quite stuck at it for a long time. so today i try to ask for new ideas. my challenge is to under stand what mistake i made. I had repaired not lesson than 50 pcs of various brands ATX psu . main pwm chip is Cm 6805 Sip 9 .
      5VSB is fine. When I short Pson, totally nothing happen. I check , the Cm 6805 VCC pin2 did have 16v, But totally nothing happen. I changed to a good chip from another good PSU. Same thing.
      What other pin should I check such that it will result in no start up at all ?
      07-07-2024, 07:06 AM
    • dariolana
      ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
      by dariolana
      Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
      Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
      02-26-2024, 07:47 PM
