repair and troubleshoot atx power supply 435 W
Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more! -
Re: repair and troubleshoot atx power supply 435 W
hmm.. i don't know that is more important on capacitance value than ESR with small value caps !! u give some useful advice.. but the problem i don't have a capacitance meter ahahaha..
i think that low value caps starts to become a problem when it is above 5 ohm? right? yeah it is defective exactly when reads as 8 ohm i thought..
haaaaah...... !!! You are really crazy man !!! Continuously I was suggesting for that third non-running Power supply and you are applying it to running power supply .... huh ... lol !!!
If your both power supply is shocking a little - that means - You have a poor Ground Source . Make a Good Ground Source - I think your problem will be solve . I don't understand, what is the problem if PSU gives little shock, PC can run fine with that little shock . Because every PSU gives a little shock .
Probably Solution For Shock - Every rail +12V, +5V, +3.3V and +5VSB has their Discharging Resistors . Look at each rail you will find 10 Ω to 100 Ω and they are 1/2W to 2W Discharging Resistor Connected in each rail . Change those Discharging Resistors . I know they are measuring good . But they are not working well-enough as a new one . So, Change them without any question . I hope your problem will be solved . If your problem do not solve by changing Discharging resistors, then you have no other option left to solve that And Make a different Post with your Third PSU which does not run at all .
i think same as you that maybe the power supply don't have a good grounding..sorry for late announcement that my power supply have a voltage again... and the third one i wanna be post a new thread.. for note.. maybe it just a bad soldering on my pcb i think.. it just magically has a voltage when i desolder to see maybe where is the defective ones near transformer.. and after i am soldering it again it has a voltage !!! guess what !! with a little electric shock..
yeah i think that i wanna be change that resistor u means about it.. of course likes u said that resistor checked good. but that don't me bother to try fix it with ur solution... btw thank you very much for all of you advicing me.. the next is post a new thread about my cheapy third one.. i just think that's not valuable to fix it because it just a really bad psu i think.. with any cheapy component right at the psu.. but i wanna make a bench power supply from my that third one and experiment with some mods... hahahaha... lol.
anyway.. i want ask something that maybe looks funny question but is that safety and long last when i changed that Y caps with same value but it just have a 275V AC..? i just think that 275V AC is above my mains voltage but i know that switching psu is really really high voltage insidely when operate..Y caps before has a 1Kv of course...
but i have ever try to measure ceramic caps and some caps didn't make deflection.. is that normal? i just make my ESR meter from googling and looks linear with my VOM.."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
Have you tried on different plug, for example in another room?
I meant electrolytic caps, they are made from 0,1 uF up. Most EST meters don't read such low values, but my ESR Micro v4.0 does, from 0,1 uF to 65535 uF
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
hmm.. why i can' t think like that before. so stupid me. lol. i haven' t try it..
ohh. i just makes wrong assume becoz my bad english. sorry. yeah i know the digital one's i have ever googling does measure with low value caps but the colleger likes me just hope a useful one's cheap enough for built..haha. i just do my free time to satisfy my hobby in electronica..Last edited by senz_90; 09-13-2013, 03:02 AM."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Assuming...7 Photos -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by sam_sam_samI found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
One other check that... - Loading...
