cap question
  • ivtec
    • Dec 2008
    • 1967
    cap question
    Hi guys:i had here a satllite receiver that failed so i troubleshooted iti found a eletrolitic cap out of specs in the power so idid not same size same specs to fit there 4700uf,10v 105degrees,so on my scrap i found a biger cap olmost double size it did not fit there,and same 4700uf but 25v 85 degrees, then i soldered extra legs from some jumpers to the existing legs and soldered it in place,end of history it works now great,my question will it fail on the long run? or it'll be ok and i don't have to order same caps anymore for now,
    i hate to make an order on my credit card just for 2 or 3 dollares?
  • ivtec
    • Dec 2008
    • 1967
    Re: cap question
    Just want to add it's Michicon electrolitic 4700 10v 85degree fer cap
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Re: cap question
      I doubt it will last long, it's rated at 85C and the old one 105C. If the original was 105C then chances are it's in a high stress job, probably output filtering. What was the brand and series of the original? This one should work at least until you can order a new one though
      • Behemot
        • 4845
        • CZ
        Re: cap question
        Pics or didn't happen.
        Generaly it is not a problem to use different spec'ed caps but you have to be sure (more or less) what exactly are you using and what will be the conditions there in the place you are soldering them in.
        • ivtec
          • Dec 2008
          • 1967
          Re: cap question
          Thanks Behemot for the intrest this temporare fix till i figuer out the right part,the cap that was there is a G-Luxon 4700uf 10v SM 105c 810 P(M)
          these are the pics
          • Behemot
            • 4845
            • CZ
            Re: cap question
            Both are general purpose even though the Nichicon has higher ripple current due to the dimensions. It may work fine but true is it is old series I think and it has 1/4 the rated life of the original capacitor so it may fail soon.
            If I am not mistaken, other caps in there are also bulging (I think I see Sam Young KMG and some Crapxon) so you will need to open in once more anyway, it cannot stay this way. Since it has been tested ESR-wise and usually lower-capacity higher-quality cap is better than the other way around, I think you can replace them quite fine with low-ESR caps of appropriate size in highest capacity you find. For example Chemi-Con KY is great line, or the newest KYA with higher capacity for every can size.
            There is also possibility that you may lower the rated voltage, quite often caps for higher-than-circuit-working voltage are used (they have lower ESR and so). In that way you can increase their rated capacity so you may end with more or less the same nominal capacity. Check what voltages the caps filter and shop according to that
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Re: cap question
              these are the pics
              I think this will probably be a good replacement.
              Can you give us a list of the other capacitors in the power supply?
              The info we need is the diameter (in mm), the height (in mm), the capacitance, the voltage rating, and the distance between the legs of the capacitor (again, in mm).
              Muh-soggy-knee
              • Behemot
                • 4845
                • CZ
                Re: cap question
                The KY is somewhat pricier but has 10000 hours endurance in this size.
                • ivtec
                  • Dec 2008
                  • 1967
                  Re: cap question
                  Thanks guys i already have order the same specs, as for theother they are ok.
                  this one that i replaced has failed on all of this receivers by the hundreds.
                  thanks anyway
                  • Califauna
                    Short cirucit across UART chip legs.
                    by Califauna
                    Hi all. First post here.
                    I have an EKS XP10 midi controller with a Burr Brown DAC. When plugging in the controller it isn't being recognised by Windows. I have two more of the same controllers. Only this one has this problem.
                    I have looked and found that two of the legs on the UART chip, at the bottom of the picture, are shorted. These are not shorted on the good boards I have. It's possible to see a little metal exposed under there between the legs. Not sure why as I didn't think there should be track there.
                    What's the recommended fix for this? Snipping...
                    07-22-2020, 08:58 AM
                  • DjKrish
                    Looking for help about a RGB LED and its specifications
                    by DjKrish
                    Hi everyone, im in need some help about a 5mm common anode rgb led. I just couldn't find this specs anywhere. The legs are as follow
                    1. Blue
                    2. Common anode
                    3. Red
                    4. Green​
                    I noticed everywhere else they are selling diff color and legs but i couldn't find the specs im looking for. Any kind soul care to help me on this?...
                    10-02-2024, 03:08 AM
                  • SluggerB
                    Can't find exact matching caps for replacements, what should I get to prevent video issues?
                    by SluggerB
                    I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
                    I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
                    The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
                    04-05-2024, 07:47 PM
                  • BrentH561
                    Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
                    by BrentH561
                    Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
                    Here is the hardware identification specs:
                    HP EliteDesk 800 G6 SFF
                    Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                    Serial No: MXL1223499
                    Product No: 26S74UT#ABA
                    BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
                    08-23-2024, 08:36 AM
                  • badcap111
                    How to read inductor specs?
                    by badcap111
                    I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
                    INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
                    I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
                    09-12-2023, 01:25 PM
