Allied AL-C350ATX bad caps
  • Rainbow
    • Aug 2005
    • 1375
    Allied AL-C350ATX - another crap by DEER. Note the 2005 on the small sticker
    And let's see why it was thrown away:
    It's full of bad caps:
    This looked like a Nippon chemicon cap from top but I knew it can't be true:
    New caps: Nippon chemicon 1200uF/16V, YAGEO 2200uF/16V and one KOME 1000uF/16V
    The bad crap:
    Remember the sticker saying temperature controlled fan? That was probably the cause why it died so fast - the fan was running VERY slow and some moron placed the dummy load resistors right next to the (crappy) caps! I shorted the NTC termistor to force the fan to run at full speed - that will hopefully make it live a bit longer.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Allied AL-C350ATX bad caps
    Judging from those TO-220 rectifiers and their heatsink, that's probably an "honest" 200W-250W. And I'd derate those +5V, +3.3V and +12V O/Ps 30%-50% from what the label says.
    PeteS in CA
    • Rainbow
      • Aug 2005
      • 1375
      It's one of the better ones (except for the caps and slow fan originally) - the input caps are 470uF, the input filter is populated, there is no fake two-diodes-soldered-together rectifier, the fan is Foxconn and was probably covered by real fan grill (it was missing - probably someone removed it) insted of standard cut-outs.
      • linuxguru
        • Apr 2005
        • 1564
        As Deers go, it's not too bad. As PeteS said, it's good for about 200 - 250 W. If you've got space for 12.5mm caps on the +12v rail, you may want to consider 15000-hour NCC 2200/16 LXF for that rail instead of the Yageos (part of the Teapo conglomerate). The NCC 1200/16 KZE is one of my favourite 10mm caps, along with the 1500/16 LXZ (the LXZ is probably more durable in a PSU). Also replace the 22 or 47 uF primary-side cap next to the auxiliary flyback, if that cap is present.
        For the TO220 12v rectifier, I found fairly inexpensive and durable subs - MOSPEC S20C200 (20A, 200V) and Vishay BYQ28E-200 (10A, 200V) for use in place of the paired 2 x FR302 normally found on the cheaper Deers.
        The fan can be replaced with an NMB/Minabea 3110-KL or similar 3" ball-bearing fan.
        • pretorianm
          • Apr 2008
          Hello, would like to ask if someone can tell me the size of the resistors (the ones on the second attachament picture - grey one) as my has probably cooked and all colors can not be recognised (the grey one in the front on this img: http://img440.*************/img440/6...pim05109td.jpg and also the pink one under the yellow cables as well)
          Many thanks.....
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
