Is it possible? If so, what would you need to do?
Convert 230V only PSU to 115V?
Re: Convert 230V only PSU to 115V?
If there are two large electrolytics after the rectifier, connect that mid-point to one of the "AC" legs of the rectifier.
This may help:
http://www.pavouk.org/hw/atxps.html
Look at how the voltage selector switch is wired.
If there's only a single cap, it's probably got APFC. In that case, running on lower voltage will depend on the design of the APFC booster.
There are 120V-only supplies which use a single bulk filter cap, but not most (all?) PC supplies."pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made! -
If it's because it only has half-range APFC, then the procedure will be a little different. You basically just need to beef up the primary side parts to make it capable of sustaining full load at 115V.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Thanks for the reply. It is a voltage doubler. When you say "connect that" mid-point to one of the AC legs, what are you referring to?
Edit: Oh okay I see SW1 and SW2 holes in the PCB, so I could just put a voltage selector switch there and it should work?Last edited by Pentium4; 07-30-2013, 12:11 AM.Comment
Those two caps:
(ASSuming you've got a packaged bridge rectifier, like a KBL406)
The positive of one (call it C1) will go to the "+" from the rectifier
The negative from the other (call it C2) will go to the "-" from the rectifier
The negative of C1 will go to the positive of C2. This center-point, in supplies with the "voltage select" switch, is connected to the AC line, when in the "120V" position.
See how the switch works with C5 and C6 in the diagram? That center point does not connect to the line when set to "240V," otherwise, each cap would have ~340V across it!
But for 120V-only use and no switch, you need to run a jumper to permanently "set" it up as a doubler. Connect the jumper from that center point to either outer leg of the rectifier. If you've got four individual diodes instead, trace back and make sure you're going to either line or neutral with that jumper! If you connect the center point to the wrong diode lead, you'll partially short the rectifier out.
EOL it...
guilty of being cheap-made!Comment
That should've been "to either inner leg of the rectifier." One of the two leads with the "~" by them.
Sorry for the bad info...
Just make sure one "SW" point goes to either "~" and the other "SW" goes to that cap "center-link."Last edited by kaboom; 07-30-2013, 02:45 AM."pokemon go... to hell!"
EOL it...
One thing that I just thought about, do you think it would be a good idea to replace the fuse with a higher amperage? Since it was designed for 230V, it has a 6.3A 250V fuse, would it be a good idea to replace it with a 8A or 10A 250V fuse?Comment
Originally posted by Pentium4No worries man that's what I thought you meant will try it out today!If ya followed my advice, you would've pulled a "kaboom," hehe...
The 6.3A should be fine. That's still 756VA at 120V- plenty. Even at .7PF and 65% efficiency, that's still good for ~345W output.
They tend to be sort of overfused anyway, with semis "protecting" the fuses.
It would be great if I could see more of that board, specifically from its AC input up to the line rectifier. There may be a place for a thermistor- it looks like there's a place for one where a jumper has been "substituted."
Quite typical. That thermistor is omitted and a too-large fuse is used, to allow for the surge of those two caps charging."pokemon go... to hell!"
EOL it...
That's why it's never a good idea to be "Inside a power supply" late at night!If ya followed my advice, you would've pulled a "kaboom," hehe...
Quite typical. That thermistor is omitted and a too-large fuse is used, to allow for the surge of those two caps charging.Last edited by Pentium4; 07-30-2013, 01:35 PM.Comment
Yes.
If this PS doesn't have a line switch, adding an NTC will greatly reduce sparking when you plug it in. It'll reduce the inrush the two caps and rectifier see as well. If it does have a line switch, an NTC will reduce wear on its contacts.
What make/model is this power supply? Or, with the "ChaChang" caps, would you rather not tell?"pokemon go... to hell!"
EOL it...
2.5 ohms at 25 degrees Celcius, and supposedly 8A average. They run hot at their full rating, so it's always better to oversize. At 2.5 ohms, it'll still "thump" a little, but better than no resistance at all.
Is that thermistor 3/4"-7/8" in diameter and about 3/16" thick?
It's "soiteny" an improvement!
EOL it...
I was pleasantly surprised to see the 560uF Cheng input caps test 575uF. I don't know a whole lot about MOV's, what are the most important specs? Are 7mm MOV's sufficient or are bigger ones recommended? I have some 7N271K's here http://www.gemkenz.com.tw/Varistor/N7%20TYPE.htmComment
Obviously, in order for MOVs to conduct, the voltage across them must rise above their rating. As the MOVs will be across the caps, guess what have to charge up first?
I'd personally settle for equalizing resistors w/o MOVs rather than MOVs and no equalizers, provided there's some form of an input filter.
I could suggest better if I actually saw that portion of the board.
Add them if you want, but make sure those equalizing resistors are there."pokemon go... to hell!"
EOL it...
My apologies for not having anymore pictures up, I will take some tomorrow. Thanks for the consistent repliesThe two slots are labelled ZR2 and ZR3. I don't think it has bleed resistors either
so I just unplugged it while it was running and the caps went down to 0.33V
You should also have a "ZR1." Either across the line, or from either + or - of the DC bus to GND/chassis.
They're not bleeders, they are equalizers! When they are connected in series, without the "center link" connected to anything, small leakage currents can cause each cap to have slightly different voltages.
Ex- 240V in, rectified not doubled, with extreme leakage: 340 across both, with one having 140V and the other having 200V. The two resistors even this out. Again, that was an extreme example to illustrate the purpose of those resistors.
Equalizers usually draw a milliamp or so. Or usually ten times the leakage of the particular caps in the ckt. Bleeders draw more current, and are [i]specifically[/i used/sized to discharge x microfarads in y seconds.
Your caps discharged quickly because the unit was running from them.
Usually, you end up with 40-80V left when unplugging-while-running, because of low voltage cutoff. Sounds like this supply will "attempt" to run even with low line voltage- could be stressful to the switchers."pokemon go... to hell!"
EOL it...
I was just also mentioning that it has no bleedersit's pretty empty there... thanks for the info!! And I know you said a jumper would do but I added the switch anyways because I had some just sitting around, so I figured why not. Added some pics, will try and get a solder shot soon too
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
The TV does not turn on, the standby indicator is on. All voltages are present.
Emms is dead. Not readable, not detected.
Replaced emmc.
But with another dump there is no launch
Terminal log
UART
AC_ON
RPMB key is not yet programmed
HASH1_VERSION=0x00000000 64bit
E-B
FDE enabled
layout pattern onebin by SAR7,0... -
This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 11:17 AM
by szxSo I have a TCL 55P607 I'm pretty happy with. However, I'm about to relocate to the UK and, to the best of my understanding, the power supply board (40-PN2G1L-PWB1CG / 08-PN2G10L-PW200AA) is 100-120V only, which means it won't work as is.
While I could just get a transformer, I was wondering if it was possible to replace this part with an equivalent 230V-capable part, e.g. from the similar looking 55P615 model.
Does this have any chance of working? If so, how would one go about identifying the best replacement part?
Cheers! -
by GnatGoSplatAntec BP500U PSU fried in my wife's gaming PC. I smelled something unpleasant last night, so I had a hunch something might be amiss. Woke up this morning to a popped breaker and immediately assumed the APFC cap must have blown. I last fixed it sometime in 2011, there's a thread about it here someplace. APFC and secondary caps that time. Replaced them with Panasonic caps. 10+yrs is probably a good run. It's been running 24/7 the last 3yrs, eth mining with a 1070ti and AFK fishing in Black Desert Online, lol.
Anyway, cracked it open this morning, expecting it to just be the APFC cap... -
by Prabuthpwwaa la-6847p rev 1.0 Convert graphics DIS to UMA. Please help.
ATI to Intel Graphics.
Toshiba Satellite C660-1m005-31-2025, 12:45 AM - Loading...
