Corsair TX650
  • newtothis
    • Mar 2013
    • 1556
    • england
    Corsair TX650
    I was given this power supply after it went bang... Upon opening and checking the circuit I found a few SMD resistors that were fried... an SMD MOSFET that had totally vaporized and a burnt through hole resistor, I managed to read the SMD components and replace those and MOSFET...
    Problem:
    The Through Hole Resistor has burnt any recognition of rating bands... Is there any way to determine what resistor should be there without a schematic?
  • tmiha71
    • Apr 2010
    • 130
    Re: Corsair TX650
    Post picture of it, maybe someone has it, and is willing to help... Be patient...
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      Re: Corsair TX650
      This belongs into the power supply forum.
      I can put text here?!
      • CG2
        LED uplighter dimmer burnt resistor
        by CG2
        I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
        02-14-2024, 09:23 AM
      • trickartt
        Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
        by trickartt
        Hello Badcaps!
        I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
        This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
        05-04-2024, 12:07 PM
      • sparcktikus
        Ersa Rds 80 soldering station burnt resistor
        by sparcktikus
        Hi
        I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
        I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
        The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
        Many thanks...
        04-04-2023, 04:29 AM
      • electomech-fixer
        First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
        by electomech-fixer
        I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
        I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
        09-15-2025, 01:42 AM
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
