I got two Seasonic OEMs with no power good signal. The 400W I've just jumpered to +5 V and left in bitcoin miner. Recapped ofc first, it works with no problems for two weeks now, 24/7.
The other, 500W, I tried to repair by swapping the daughterboard with secondary IC (from my dead old Seasonic) which shoudl give the PG signal. They are the same and mine should be working with 99,9% chance. But no change.
Initially I found one SMD resistor torn off the main PCB so I soldered it back. Was not sure with the soldering so I changed it for small ordinary axial resistor (same value - 100 ohms) but still nothing. So am thinking about just leaving it be as it most likely otherwise works normaly as long as I apply +5 V to the power good for MB to turn on.
So I am just thinking, is it safe in long-term? Well, the PSU could go bad, but the PG should not matter for that because if it goes over/under votlage, it should shut down the PSU itself, so no problem if it won't shut down MB fist, right? It does not have any means of OCP/OPP so this won't matter as well. And if I'll recap the PSU, what chance it even is there for it to go bad?
Half of the computer problems is caused by bad contacts
) and one strange behavior. When unjumpered, 32 A output on +12 V without problems and with +-50 mV ripple.
