RANT: Apple magsafe adapters are a fire hazard!
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    So today someone's genuine apple magsafe adapter caught fire where the low voltage output wires come out of the case. I managed to cut the wire and resolder, so the cord is a little shorter now (it doesn't catch fire anymore though!)
    Sorry no pictures, I was in a hurry to fix it LOL, then found that the solder was nowhere to be found, and I had to go get some...
    So yeah, the strain relief is just poorly designed. The psu is made by delta, and it has Nichicon capacitors inside
    Again, the strain relief is crappy, it is waaaay too stiff to work as a proper strain relief.
    Any of you had these do the same?
    BTW, it was an 85W one, but the 45W ones have the same stupid design...
    Edit: here is an example of what it was doing: http://www.youtube.com/watch?v=ghqX5L7kzg8
    Muh-soggy-knee
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: RANT: Apple magsafe adapters are a fire hazard!
    Out of curiosity... what series of Nichicon capacitors did you see in there? There was another Delta-made 85W Magsafe adapter posted to this forum a couple years back and it had Rubycon ZLH caps.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      The secondary side capacitors were HD series, I think.
      Muh-soggy-knee
      • smason
        • 1652
        Holy crap! You'd think it would shut down with that sudden current draw.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Yeah!
          Muh-soggy-knee
          • Khron
            • Sep 2006
            • 1350
            • Finland
            What're the odds Apple forgot to / didn't choose to specify OCP in their design request?
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              _
              My guess: 99.9%
              Just kidding LOL
              In fact, there was a silly bodge in the adapter, Apple added in a 5a fuse on the output. But the pay probably turns itself off and on from the short circuit, instead of blowing the fuse, which takes time because the fuse link has to heat up... sorry I forgot to mention about the bodge fuse
              Muh-soggy-knee
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                One last thing... if you don't mind me asking, ben, do you remember the model number of the Delta Magsafe adapter in question?
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  No I don't, but I could sometime next week. Why?
                  Muh-soggy-knee
                  • Wester547
                    • Nov 2011
                    • 1268
                    • USA.
                    You don't have to. I'm just wondering, IE whether different model numbers use different series of capacitors... but then capacitor series are used so interchangeably in so many products with so many little revisions that the only way to really find out would be to crack it open.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      i've seen about 7 chard magsafes just this year
                      Follow the white rabbit.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        LOL
                        Apple has some serious design issues. Now the iPhone 5 has an issue with being bent easily, even being bent right out of the package!
                        Muh-soggy-knee
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          Originally posted by ben7
                          LOL
                          LOL
                          bent as in dented or bent as in warped?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            Bent as in dented. It will happen if you put the phone in your back pocket and sit down.
                            A working TV? How boring!
                              It's nothing to do with overcurrent... it's to do with extra contact resistance leading to excessive power dissipation. P=IV...
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Kind of, but not quite right...
                                http://iphone.pandaapp.com/news/1223...l#.UbNJaDDD9cs
                                Yep, that's right! They totally messed up with the design - and they chose aluminium! Look on the web for more bent iphone porn LOL
                                Muh-soggy-knee
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  In this case it is due to the strain relief on the adapter being poorly made, out of very stiff rubber. The wire bends much easier, and so it does does (over time that is). The insulation eventually cracks and the two wires short out ... then start melting things. The wires are actually a coaxial type, both conductors being stranded wire. My idea is that the strand(s) short out but heat up due to their higher resistance, and hence the overcurrent isn't tripped. The insulation starts burning then...
                                  Muh-soggy-knee
                                  • spleenharvester
                                    GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                                    by spleenharvester
                                    I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                                    07-08-2025, 06:02 PM
                                    HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                    This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                    09-12-2024, 02:30 PM
                                    HP ProBook 450 G7 + Apple AirPods Pro Notebook 400 Specification for Upgrade or Repair
                                    This specification for the HP ProBook 450 G7 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Apple AirPods Pro boardview and 450 G7 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                    09-06-2024, 07:50 PM
                                    HP EliteBook 850 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook 850 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G6 + Apple AirPods Pro boardview and 850 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
