Powermate UPS bad electrolytics?
  • jeepster
    • Nov 2010
    I have a Powermate 9120 UPS. After replacing the batteries, it came up
    with "DC bus fault"
    My first guess was that the batteries were not connected properly,
    or maybe a relay had burnt out.
    Then I found in a Finnish forum that this fault was cured by replacing
    two capacitors. The poster further claimed that this was a frequent
    failure in these models.
    Has anybody fixed this brand of UPS and found bad caps are the culprit?
  • japlytic
    • Oct 2005
    • 2086
    Re: Powermate UPS bad electrolytics?
    Welcome, jeepster!
    Do you mean Powerware?
    Some pictures of the boards would be helpful.
    • lti
      • May 2011
      • 2558
      It looks like bad caps could be the problem, but there might also be something else wrong with it.
      https://www.badcaps.net/forum/showthread.php?t=13768
      • cheapie
        null
        • Jul 2010
        • 849
        Yes.
        • carrzkiss
          Cyberpower cps1500avr not charging batteries
          by carrzkiss
          Hello, all.
          Cyberpower Battery Backup Unit.
          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
          Checking the voltage, it was down to 22v.
          I quickly removed everything...
          06-15-2024, 02:10 PM
        • howardc64
          Where do repair shops buy MB replacement batteries?
          by howardc64
          Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
          Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
          BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
          07-25-2024, 10:42 AM
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
        • Rictech
          Panasonic SA-MAX770PU SMPSU board fault....
          by Rictech
          Hello everyone. 😀
          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
          There are no devices that have exploded or otherwise show signs...
          08-26-2024, 01:05 AM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
