Hello.
I have few questions I wanna ask you guy's/girl's
1. What is the difference on PSU (Power Supply Unit) and an Adapter?
I ask this because of language barrier.
2. I've noticed on some PSU's/Adapters they are said to be certain voltage
but when I measure them they show much higher voltage.
Example: I have a linksys adapter "Model:AD 12/0.5A" it say's that it's
supposed to give 12v output, but when I measure it, it gives me a reading of 17.6v
Is this normal? On other adapters I've measured the correct voltage.
I've noticed even for the higher voltage the appliance still works and shows
no symptom of malfunction.
Is it ok for me to use them even they are showing higher voltage then given up?
This is the adapter in the example http://azsurplus.com/index.php?main_...oducts_id=1911
3. Is it right that some adapters don't show any voltage when I measure them
with a multimeter because the multimeter does not drain any power from the adapter?
And the only way for me to measure them is to use a light bulb or anything like that so the adapter "knows" that it is connected. (something to drain power from the adapter)
4. Can I charge a battery by only connecting the bare wires from an adapter
to the poles of the battery? with out using any electronic equipment?
I'm talking about rechargeable batteries of course, like 1.5v or even 12v
With hope of detailed answers.
Half of the computer problems is caused by bad contacts
