Dvdr died. So I pulled the PCB and found a short at d1063 diode fr302. Got to order one and see if it works. Anything else I should check?
phillips dvdr3506 bad diode
by asrHello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks.... -
by unimatrix93Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
The led strips has 9 6V leds.
1 Photo -
by BasteHello experts,
Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
Aneng ST182 Meter.
Diode mode.
MBR3045CT:
Diode mode
Pin 2-1 - 0.150v
Pin 2-3 - 0.150v ...4 Photos -
by NicRacHello everybody☺️ I am glad to be here and looking forward to a good discussion.
First of all, I am new here. Therefore I will shortly introduce myself.
I am Nico and currently I study Physics.
In my freetime I like to build and repair stuff. Especially big battery's.
A few years ago I got myself an electric unicycle, monowheel or however you call that.
The battery bms was broken so I replaced and resolder that. Nothing big.
I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...5 Photos -
by dennis_elx33Hello Everyone,
I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
While compared to the reading of another diode from the next channel it won't read at reverse bias.
Now the problem is; it does not have any body marking.
So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
What do you think is this diode?
Can you please suggest what part number can i use to replace this faulty diode instead?
Hoping that you... - Loading...
