This SL-400 is one that I recently resurrected in another thread. The entire reason I rebuilt it was to experiment with it in various ways. One of the things I wanted to do was to get rid of the two transistor 5vsb and replace it with something better. Although the Viper22A is an option it has several drawbacks especially in a surface mount package which I wanted to use for this project. Everell had found the NCP1200 driving the 5vsb FET on a power supply that had a 5A 5vsb circuit. If this chip would work it seemed like an ideal solution.
I removed all the components that would not be used with the NCP1200 circuit. The big difference in this modification and the Viper22A mod is that the 5vsb FET attached to the heat sink will be used. I am attaching pictures of the power supply before, during, and after modification. I will make another post with the load test results.
