LeCroy 93xx power supply
  • japlytic
    • Oct 2005
    • 2086
    Last night, I found that my LeCroy 9314AL would not start (the cooling fan starts to rotate and then stop, and then the power supply makes a ticking sound).
    Earlier on, the scope program crashed and later had trouble starting.
    So I decided to replace all but the still-good two 470uF 200V electrolytic capacitors, which were mostly Nichicon PL, some Nichicon PF and a few Nichicon VX, and this fixed the problem.
    I also replaced the clear epoxy Rifa X and Y capacitors, of which in my experience can be problematic.
    Before I connected the power supply to the scope mainframe, I checked that the output voltage were within tolerance and all were good - an important step to prevent damage from a repair that could be improper.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
  • repair-it
    Need advice testing a samsung power supply board with scope
    by repair-it
    I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
    07-12-2025, 11:00 AM
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
