Pyramid PS-52KX Power Supply Fixed!
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Got this from a client. He used it for the demo board of his car stereo store.
    There is a reason why Pyramid was cheap, it's not a well designed power unit.
    All kinds of 'half assed' stuff was built into it's design.
    It was a mess.
    All kinds of parts were blown out in this thing.
    Most of them because of poor engineering.
    The idiots used black anodize screws.
    For some things they look great, but as conductors of voltage, they don't always work.
    Anodizing is an insulator.
    So when things don't conduct well, they get hot, and that kills transistors.
    Speaking of transistors, all eight output transistors were wiped out.
    I put in new ones.
    The OEM failed to torque down a main power diode, that too went into the trash heap.
    New one came out of the parts bin.
    Among anther things that got wiped out were two resistors and the main regulator IC.
    Got about three or four hours into it.
    http://www.flickr.com/photos/9010884...7632568360299/
    Found the schematic c/o the Repeater Builders web site, many thanks to them.
    Jack Crow
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • CMCM
    Russound CA4 Power Supply Repair
    by CMCM
    Hello Everybody,
    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
    The outputs marked 12v and 20v are all measuring only 1v.
    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
    The capacitors physically look clean (no bludgesor leaks) and...
    07-03-2025, 01:12 PM
