Pyramid PS-52KX Power Supply Fixed!
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Got this from a client. He used it for the demo board of his car stereo store.
    There is a reason why Pyramid was cheap, it's not a well designed power unit.
    All kinds of 'half assed' stuff was built into it's design.
    It was a mess.
    All kinds of parts were blown out in this thing.
    Most of them because of poor engineering.
    The idiots used black anodize screws.
    For some things they look great, but as conductors of voltage, they don't always work.
    Anodizing is an insulator.
    So when things don't conduct well, they get hot, and that kills transistors.
    Speaking of transistors, all eight output transistors were wiped out.
    I put in new ones.
    The OEM failed to torque down a main power diode, that too went into the trash heap.
    New one came out of the parts bin.
    Among anther things that got wiped out were two resistors and the main regulator IC.
    Got about three or four hours into it.
    http://www.flickr.com/photos/9010884...7632568360299/
    Found the schematic c/o the Repeater Builders web site, many thanks to them.
    Jack Crow
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
