Standardization for modular internal computer power supplies
  • japlytic
    • Oct 2005
    • 2086
    I am still trying to find an industry standard for connectors and leads on modular computer power supplies (internal type) - and I doubt there would ever be an industry standard, because it is apparently specific to a manufacturer and/or series.
  • mariushm
    • May 2011
    • 3799
    Re: Standardization for modular internal computer power supplies
    Each manufacturer tends to standardize their own cables to a single format.
    In the past it was no possible because everyone had to work around patents related to modular cables (I think Ultra had some patent on modular cable)
    http://www.google.com/patents/about?id=w0ehAAAAEBAJ
    http://www.google.com/patents/about?id=iOGqAAAAEBAJ
    So they had to carefully make the modular connectors around what the patents claimed.
    I'm not exactly sure but I think the Ultra patent was invalidated... but I may be confusing the patent with the one for 140 mm fans.. there was one for this stupidity, and because of this a lot of manufacturers advertised 139.5mm fans on the packaging.
    • Giggle2562
      Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
      by Giggle2562
      I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
      The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
      Here's what I've tried so far:
      • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
      • The laptop shows an image on the internal display for a few seconds before it shuts down.
      • I tried swapping the LCD panel with a known good one.
      • I tried swapping the LCD cable
      11-06-2025, 12:36 PM
    • joshAU
      How to trick notebook into thinking internal panel is connected?
      by joshAU
      Hi all.
      I have an asus F505DV that has a smashed screen, broken hinges, bezel and top cover.
      The customer cannot afford to repair it, so they wanted me to remove the top of the unit and will just use the base as a desktop and plug into a monitor via HDMI.
      However, for some reason, with this model, it REFUSES to display on the external monitor unless there is also an internal LCD.
      If there is a internal screen, then the external displays fine.
      This is running the latest BIOS.
      I have set the display properties in windows 10 using...
      10-06-2022, 11:04 PM
    • lanovey
      SF314-41 BIOS without internal display
      by lanovey
      Hello there,
      I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
      I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
      06-13-2025, 02:38 AM
    • Rangry
      Razer Blade 15 2022, No internal display, Error Code 43
      by Rangry
      Hi! I have a Razer Blade 15 2022, with a RTX 3060.
      One day, while using Linux, the internal display suddenly stopped working.
      On Windows, it says that the internal GPU has stopped working (with error code 43).
      I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
      I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting...
      05-29-2025, 07:01 AM
      HP Z800 E5530 Specification for Upgrade or Repair
      This specification for the HP Z800 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z800 boardview and Z800 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z800 is accurate, safe, error...
      09-12-2024, 03:30 PM
