Lower output voltage from 12V to 8V possible ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Got this 12V 1.5A psu and I wonder if it is possible to lower the output voltage to 8-9 V ?
    I have no idea if it is possible without redesigning the whole psu or changing the transformer.
    The TO220 on the left is a SB10100FCT and the TO220 on the right is a KSH13007A if it matters.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Lower output voltage from 12V to 8V possible ?
    Possible, just that it'll need a higher minimum load to work properly.
    You can adjust output voltage by adjusting the resistors on the TL431, which is the TO-92 package on the secondary side of the optocoupler. Just to the left of it in picture 2.
    The TL431 will have a voltage divider from output to ground, with its middle point connected to pin 3, by replacing the lower resistor of the divider (the one which goes from pin 3 to ground), with a higher value it is possible to decrease the output voltage.
    A working TV? How boring!
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      Holy crap, how would you know that ? sometimes it hurts when I think about what bus to get on just to go home.
      Will have a look at this tomorrow.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Looks like R11, the through-hole resistor next to the TL431, is the lower resistor (from adjust (pin 3) to ground).
        Looks half decent, with a fuse, and input filtering. I'd just replace those caps too
        Muh-soggy-knee
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          Just got it working.
          1.3Kohm 12.11V
          1.5Kohm 11.04V
          2Kohm 8.89V
          2.2Kohm 8.33V
          Ended up using a 2.2Kohm resistor for R11, I see no voltage drop under load.
          I'm using this for a brother p-touch label writer which draws 6W - no problem so far.
          What are the drawbacks changing the output voltage this way ? more rippel ? less efficiency ? possibility for psu to oscillate ?
          Why does this psu have no lytic startup cap as many other have ?
          Th3_uN1Qu3 and ben7, thanks a lot for your help - Both of you were spot on.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            1.3Kohm 12.11V
            1.5Kohm 11.04V
            2Kohm 8.89V
            2.2Kohm 8.33V
            This PSU appears to be a self-resonant type. So yes, it might oscillate. But that is much more likely if the capacitors on the secondary go bad, since there is no 'critical' capacitor on the primary side.
            This 'critical' capacitor would, in certain computer power supplies, such as the infamous Bestec ATX-250 's, cause the normal oscillation to go wacky. The output voltage can go from the normal 5v, to 20+ volts! This easily kills motherboards.
            As long as the secondary rectifier diode could handle the current, this could output its original 18w spec (12v, 1.5A) at 8v - which would be 2.25A. So It will provide plenty of power for the label writer machine.
            Moreover, Th3_uN1Qu3 knows a crap-ton about SMPS design , so I am sure he will have more to say (or possibly correct me )
            Muh-soggy-knee
              You also have to consider capacitor ripple current and transformer ratings.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                I thought so, but wasn't sure - better to keep my spewing mouth shut
                Muh-soggy-knee
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  It comes from experience. Seen and fixed many of them, have a prototype right now on my bench, that i built myself from the ground up. Anytime i see an opto with a TO-92 next to it, i immediately think TL431.
                  Mostly stability issues. Two things happen at low load when a SMPS of this kind is modified for lower output voltage. First, the gain of the circuit increases, which means the crossover frequency increases as well. This can lead to oscillation at low load. Secondly, even though this is a self-oscillating design, it still has an auxiliary bias winding that provides the voltage for driving the power device (as a matter of fact, this is what starts up the oscillation in the first place). When you lower the output voltage, the voltage on this winding decreases as well, so it takes a higher minimum load at the lower voltage, for the auxiliary winding to come up to its designed operating parameters.
                  If the device you are powering draws a fairly constant amount of power, above the minimum load limit of your SMPS, this will not be a problem. You will recognize a too low load by a characteristic ticking sound coming from the transformer - this is commonly known as "hiccuping". It is a low frequency oscillation that occurs when the voltage on the aux winding drops too low to continuously power the circuit on the primary, so oscillation stops for a little while, then after building up enough voltage it resumes, and so on. A power supply operating in this mode will interfere with the attached device.
                  Ripple will not be an issue unless you pull more current from it than it was originally rated for.
                  • Gabriel
                    • Jan 2010
                    • 620
                    • Norway
                    How would you know what the minimum load limit would be ? is it possible to calculate it based on the components ?
                    Is it a better idea to fit a lower ohm resistor to a 5V supply to get it up to 8V compared to fit a higher ohm resistor to a 12V supply to lower it to 8V for stability reasons ?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      It's dependent upon the topology, control method used, number of turns on the auxiliary winding... It can't be calculated without a full schematic, including inductances of the transformer.
                      Largely, yes.
                        I've played around a lot with the self-oscillating two transistor design. I kind of finally understand it -- ish. The auxillary winding is important for start up but it forms a much more important part of the operation of the supply. It essentially drives the MOSFET gate effectively allowing it to operate at high frequency and reasonable efficiency. The gate drive capacitor couples the drive pulses so the supply can start up (a large capacitor slows start up but increases drive current.)
                        This design will also start up with just the load from charging the output capacitors up, then hiccup to keep the output in regulation, and still be fine with heavy load after doing so. See below. It doesn't require a TL431, can just use a zener for feedback.
                        Only real application I can see a supply like this useful for is driving LEDs. It's very efficient and cheap. For standby supplies it's too expensive to implement for more than about 2A. Though I have seen a three-transistor variant in a 32" LCD TV... for the backlight inverter power! (About 150W.)
                        • electron_jj
                          Panasonic TH-L42D25A checking the PSU output voltage
                          by electron_jj
                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                          08-29-2021, 08:13 AM
                        • David Miteff
                          NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                          by David Miteff
                          Hello, guys!
                          As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                          As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                          12-30-2024, 07:02 AM
                        • bauto601
                          KDM 480W PSU upgrade succes! (opinions?)
                          by bauto601
                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                          A "nice" YoungYear unit? - Badcaps
                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                          12-26-2023, 03:05 PM
                          MT3608 Step-Up Converter IC Datasheet
                          The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                          Internal soft-start results in small inrush current and extends battery life.
                          The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                          10-07-2024, 05:02 AM
                        • Ri5ux
                          Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                          by Ri5ux
                          Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                          Symptom: 2 Second BLOD
                          Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                          09-09-2023, 06:57 PM
