Upgrade a 300watt noname power supply
  • TELVM
    • Oct 2012
    • 547
    • Spain
    Re: Upgrade a 300watt noname power supply
    Originally posted by bauto601
    ... I don't know which rectifier is what so i don't know which is the the 3,3, 5 and 12v rectifier. Can you tell me which rectifier is what? ...
    The color of the output wires can give you a clue:
    Often the +3.3V rectifier is aligned with the orange wires, the +5V with the reds, the +12V with the yellows.
    To be sure test for continuity between the center leg of each rectifer and the orange/red/yellow wires.
    • c_hegge
      • Sep 2009
      • 5219
      On your PSU, the BYQ28E is for the 12V, the STPS2045CT is for the 5V rail, and the STPS1545CT is for the 3.3V.
      EDIT, you could use those other heat sinks, but maybe bend the fins outwards, that way, you will get some airflow between them
      • everell
        • Jan 2009
        • 1514
        Originally posted by c_hegge
        The OEM for this PSU is Channel Well (CWT).
        How can you tell that this is Channel Well and not Solytec/L&C?
        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
        • c_hegge
          • Sep 2009
          • 5219
          The part numbers on the transformers don't looks like L&C, neither do the heat sinks, and L&C have never used Fuhjyyu caps (whereas CWT love them).
          The PSU in post #20 is an L&C, though
          EDIT: Maybe I should add that the OP's PSU looks like it is from their ISO division, and so it lacks some of the usual CWT features, like green tape and CWT markings on the transformers.
          • bauto601
            • Sep 2012
            • 103
            • Netherlands
            I am very busy with school and other computer things at the moment so i will work on it in the weekend but not on school days. So it can take a little longer before i will respond to your post.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
              09-06-2024, 05:59 AM
