Help with Bentek DMC BP-200AD Power Supply
  • grzesiek
    • Jan 2011
    • 23
    Re: Help with Bentek DMC BP-200AD Power Supply
    Q4 and Q5 Test results...
    Q4 Pin 2 to Pin 1 - 728
    Pin 2 to Pin 3 - 652
    Q5 Pin 2 to Pin 1 - No reading
    Pin 2 to Pin 3 - 630
    So I guess Q5 is no Good and Q4 is good.
    Originally posted by momaka
    By the way, sorry to say, but I haven't looked at the FAN7527B and 5M0365R data sheets yet. I'll try to do that by the end of the week.
    No Problem I'm supprised you would have time to look at this at all during this week.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
      03-31-2024, 02:12 PM
    • gica69
      Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
      by gica69
      I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
      Resistor shows orange range silver gold and green lines.
      Thanks in adv...
      07-21-2025, 09:49 PM
    • Safrilhg
      Look for the resistor value in the BenQ G922HDAL monitor's power supply
      by Safrilhg
      Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
      In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
      How to determine the appropriate SMD resistor value for this condition? Thank You...
      11-06-2023, 12:43 PM
