power supply bn44-00259a dead
  • nic2
    • Dec 2012
    • 6
    • abruzzo
    Hello I have read several posts on the subject but I have not found a case similar to mine. The TV is dead no picture no sound no red light in.standby. Checked voltage CP 815 = 326 v.dc. on the power circuit BN44-00259A. The connector CNM802 provide no evidence output voltage. The capacitors seem undamaged no anomalies. I replaced two electrolytic capacitors (CP809 and CM808) leveling power of the integrated FAN 7530 and who had a ICE3BR0665J ESR too high unsuccessfully checked all the diodes and transistors involved but do not come out
    Who can help me?
    thanks
    Service Manual:
    http://elektrotanya.com/samsung_ln26.../download.html
    diagram at
    https://www.badcaps.net/forum/attachm...5&d=1300162507
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: power supply bn44-00259a dead
    Double posting will not help you - ask the mods to remove this thread.
    The members who know about tvs may be busy. Really good pictures of your boards may get a few more interested.
    • nic2
      • Dec 2012
      • 6
      • abruzzo
      I replaced the diode IN4740AS - zm801 found in short and magically the TV is on and everything is back to work properly. I could not find the diode and I used a zener diode compatible. The problem has been resolved. Thank you.
      • whiz62
        whiz62
        • Dec 2013
        • 242
        • usa
        I also had a bn44-00259a with bulging caps and that did not solve problem. Replaced zm801 and zm804 diodes and it powered on. Thanks for the tip!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
