Safe to try a Power supply that's been in the Rain?
  • DJ_MIX
    • May 2005
    • 118
    If I let the Powersupply dry for a few days would it be safe to try to see if it works?
    It's a Sparkle PS that was in the trash along with the Compusa PC..
    Either way I will gut the fan if else fails...
    Might be funny But if it's dangerous it will let others know.
  • WeStSiDePLaYa
    • Mar 2006
    • 63
    Re: Safe to try a Power supply that's been in the Rain?
    electronics+water=no problem
    electronics+water+electricity=problems
    if you let it dry out completely it will be fine.
    Specs
    DFI AM2 LANPARTY UT NF590 SLI-M2R/G
    X2 3800+EE AM2
    2x1GB OCZ PC2-6400 Platinum XTC
    XFX 7900GS
    Maxtor 6L250S0
    Maxtor 6V300F0
    Western Digital WD2500JS
    Mushkin HP-550(Cap/Filter Modded)
    Cooling
    Swiftech Apogee
    Swiftech MCW-60
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    • japlytic
      • Oct 2005
      • 2086
      Beware of conductive deposits when it is dry... try washing in methylated spirits, let it dry thoroughly, do an insulation check with a megger, if all OK, it still should be OK.
      • PeteS in CA
        • Aug 2005
        • 3578
        • USA, Unsure of Planet
        If your oven can be set as low as 200F (~95C), you might be able to put it in your oven for a half hour or an hour to be sure it is dry. 250F would be too high. I think Topcat uses quartz heaters and a big box fan to dry motherboards.
        PeteS in CA
        • arneson
          • Sep 2005
          • 1267
          So basting may not be a good idea.
          Jim
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
          • madan1
            555 based power supply getting too hot
            by madan1
            Good day.
            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
            Yesterday, 04:38 PM
