OCZ StealthXstream2 - anyone have one?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    I was wondering about the quality/mortality of PSUs after repairing two of what once thought were highly regarded Antec PSUs (SP300 and SP400) I still have a few power supplies that I wonder of their longevity.
    Since they still work I'd be hesitant to pull them apart but... who knows...
    OCZ StealthXstream2 600W (80+)
    Peering into the back I see one huge OST branded cap, which I assume is the main filter cap. The output filter caps I cannot see... One thing I DON'T see - which is a good sign - is burn marks like I see everywhere on the Antec SP400... Never a good sign when parts get hot.
    I also have an Antec NeoHE 430 (NOT 80+) which I wonder if it will suffer the same fate as the SP300 and SP400... Also have an Antec SP350 Blue (still working!) which I am now VERY suspicious...
    Also have people been finding 80+ PSUs tend to last longer? By the sole reason that more efficient = less heat = cooler capacitors = no explosions regardless of quality? (Then again if the designer took advantage of less heat to reduce fan speeds to quiet it, then there's no advantage...)
    I was down to one spare PSU before the two Antecs were repaired, it was a Raidmax 380. I believe it's a Deer... oh boy...
  • Behemot
    • 4845
    • CZ
    Re: OCZ StealthXstream2 - anyone have one?
    It's the same FSP Group design as in the very Fortron BlueStorm II I am battling with. It has totally burned +5V SB.
    What I remember, this platform often barely did 500W in ATX spec, I guess that if you loaded this one on full 600 W, you will find the ripple shooting into sky after years of service with bad caps.
    • AJ847.63e
      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
      by AJ847.63e
      Hi Folks,
      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
      05-06-2025, 10:37 PM
    • sirpsychol
      Antec Earthwatts EA-380 smd element type/value
      by sirpsychol
      While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
      09-03-2023, 07:58 PM
    • ajdrenter
      Picking caps for Antec SU-380
      by ajdrenter
      In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
      https://www.badcaps.net/forum/showthread.php?t=14159
      It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
      05-13-2023, 10:40 AM
    • CWEastwood
      Antec Smart Power SL300S capacitor replacement.
      by CWEastwood
      I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
      The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
      I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
      Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
      03-25-2023, 12:18 PM
    • s_henya
      Antec VP-600P and NE550M dead
      by s_henya
      Got in these 2 nice PSUs, both died after power surge.
      Both seems to be suffering from the same fault.
      Blown main fuse
      Shorted N mosfet 550v
      VP-600P: 5R280CE short between GDS
      NE550M: MDF18N50 short between GDS
      In terns of board layout these seems pretty identical.
      From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
      I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
      Is it worth to try and replace the mosfets? is there a chance that the...
      12-03-2024, 10:00 PM
