Fortron BlueStorm II (FSP500-60GLY) nothing but +5V SB
  • Behemot
    • 4845
    • CZ
    Hi guys,
    got this one wih "not working" status. Checked +5V SB, there was as low as 2,5 V there. Swapped bulged crapxon and also one diode on its input for beefier - the former one measured OK, but was really burned badly from heating, basically all that part is. Than it measured arround 5 V, thats OK.
    I tried to fire it up without fan, but got nothing, thought thats protection. But after recapping whole secondary and soldering in fan, I got still the same. Basically it slightly wheezes with no load, that's common for FSP I think. If I ground the green pin, the wheezing gets louder but I get no other voltage than +5V SB.
    Measured quickly for short on secondary, there is none and also it does not go into protection mode (no clicking), so I think this is not the problem. So far I haven't changed the small caps, but I think they are hopefully in not so bad condition to prevent it from start with no load. Will swap them later too.
    Any ideas what to check next? I have to go now, will shoot some photos later, so far you can grab som frome jonny for example: http://www.jonnyguru.com/modules.php...Story3&reid=84
  • mariushm
    • May 2011
    • 3799
    Re: Fortron BlueStorm II (FSP500-60GLY) nothing but +5V SB
    Check the thermistor under the secondary heatsink (and the transistor right next to it), see if the primary mosfets and secodary rectifiers are good (not shorted or open) ... go from there...
    • Behemot
      • 4845
      • CZ
      As I already stated, secondary bridges are OK. Also all transistors measured fine (including the small ones), all SMD diodes are OK and all optocouplers seem OK. The transistor with termistor over reads 6,17 kiloohms, I guess that's OK too.
      • Behemot
        • 4845
        • CZ
        Success! Swapped two small caps near the baked +5V SB circuitry and it starts normally. Gonna swap one more in there and that should be it
        • Behemot
          • 4845
          • CZ
          Bloody fucking hell, it just
          One SMD zener crap is shorted, how can I identify it's values? It's tiny SMD crap with white and black (maybe grey?) stripes.
          Found the schematics, it's the Z41 diode, any clue of what values may be there?
          ADD// had a look into datasheet for DM311; it says it wants +20 V on Vcc and starts to work on at least +9 V. So would it be safe to use 20V zener diode?
          • everell
            • Jan 2009
            • 1514
            The data sheet specifies that you must have at least Vdd 9 volts to operate properly and that 20 volts is the maximum. As you increase the loading on the +5vsb, the regulator will keep the voltage at 5 volts BUT the Vdd winding providing power to the DM311 chip will increase as the load increases. When the Vdd from this winding on the 5vsb transformer reaches the 20 volt maximum, the DM311 shuts down. That is how it protects your power supply. Usually those pwm chips have an internal zener which prevents the Vdd from going overvoltage - 20 volts in this case. If this chip does not have the zener internally, then the proper zener for you to use would be 20 volts.
            Coming directly off the zener cathode, the trace also goes to and powers the Vdd to the main pwm chip. It also has a maximum voltage, and sometimes an internal zener. I think that 20 volts would be a good zener value for that also.
            Since there is no current limiting resistor for that zener, I would recommend that you use at least a half watt zener ...... smt device OR kluge an axial component into the circuit. Since the zener is a protection device, it should not be necessary for ordinary operation. Most 5vsb circuits using the pwm chips that I have seen don't have a zener in that location. Beware that your power supply may have other problems which are causing the zener to blow. IMO just a cheap crappy part that died and shorted.
            Which two capacitors did you change that helped it start working? That will probably give us a clue as to what is going on.
            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
            • Behemot
              • 4845
              • CZ
              I changed C15 and C49. Than it worked. The last thing was probably accident - I didn't secured the PCB with screws so it may shorted somewhere. I have seen and heard huge spark
              There is, however, resistor acting as limiting - the R42 on diagram. In my case, it is 2R2, not 4R7, but it is there.
              • Behemot
                • 4845
                • CZ
                Now another zener is shorted, the Z42 on feedback. I am not sure why it is there on the first place, because on feedback, if there is over +4,5 V, the LM311 should know that, right? On the other hand, can the fototranstistor in optocoupler even produce such high voltage we would need zener?
                Anyway, it's all getting very messy. I will likely dissolder it all and start working on separate board (but have to get it first ). I will start only with the Vcc and Vfb part as the rest seems good. Also do not want to mess with input 325V, it can stay on main PCB together with the very LM311.
                • pdavid
                  • Jan 2011
                  • 279
                  • Hungary
                  I remember how much trouble I had when I first tried to fix a forton 60gly-gln whatever platform. Thanks to badcaps I fixed the standby but ultimately it turned out to be a dead ps233 supervisor.
                  I used that psu to mod another similar unit.
                  If it helps I can take some readings on some smd components while the the psu is live.
                  • Behemot
                    • 4845
                    • CZ
                    Oh, thanks, seems to be same internals
                    • pdavid
                      • Jan 2011
                      • 279
                      • Hungary
                      Okay, my scope tells me that the dm311's feedback leg gets 1.91-2.66V dcc. According to what the dm311's datasheet says I would choose a 5V zener
                      Before you replace the zener check c43, d40 and m3 opto. Maybe it got shorted somewhere on the feedback. Honesty I'm not a fan of this build because of the ps233 supervisor and the caps. I prefer forton's pnf units, despite the efficiency.
                      Hopefully you won't have much trouble fixin this though.
                      • Behemot
                        • 4845
                        • CZ
                        I heard that the PNF boards have even higher current on +12 V, so definitelly you won't tell BS used to be high-end
                        Anyway, I even desoldered half of the optocoupler and it still was shorted. As I said, it is really messy, it was darkened even before I started to operate there with my 125W transformer soldering pistol May be soldered somwhere to short but I just cannot find it.
                        For that reason I will just move all that section to a separate board and connect just wire here and there
                        • ipo3nk
                          • Mar 2011
                          • 16
                          hopefully this schematic help.
                          the z41 is 18v, & c41 100uf
                          theese parts & all secondary caps always fail after 3+ years operation.
                          thats why they only gave 2 years warranty. WTF!
                          • Behemot
                            • 4845
                            • CZ
                            Oh thanks bro, I am gonna definitelly use this. There is even more ore less whole PSU diagram in there, lets plagiate
                            • Ddsfadi
                              • Usa
                              What is the value of z42 please can any one help
                              • cnti
                                Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                                by cnti
                                Hi.
                                BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                                This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                                BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                                RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                                burned, measured 10M ohm.
                                QM801 [real PSU:...
                                10-19-2023, 05:33 PM
                              • chth96
                                How Can I test PWM DM0365R?
                                by chth96
                                Hello
                                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                06-18-2025, 04:14 PM
                              • titomno2
                                Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
                                by titomno2
                                Hi guys,
                                On motherboard ACER AN515-52 type LAF951P.
                                I fixed issue with not starting computer (it was the PQ201 component not working properly).
                                But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
                                Basically some HDD spin but are not detected by the bios.
                                Already tried following:
                                checked the 4 data lines
                                #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
                                #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
                                07-28-2024, 08:30 AM
                              • TAlbeniz
                                LG 14FU7RB doesnt turn on.
                                by TAlbeniz
                                Hello everyone
                                I am new in this forum and I need your advice. I would like to fix my grandpa tv which is LG tv 14FU7RB. I already did some research according to the board. I already measured the voltage in primary and secondary block. primary elco in primary section is 300v. STR IC pin 4 vcc 9 volt but in secondary section every dioda that supply dv voltage like 9 volt 5 volt 5 volt standby and even B+ for flyback doesnt have any voltage come out. if you guys know how to solve please help me. I want to learn to fix this TV since I am still newbie ij this kind of stuff....
                                03-04-2025, 03:49 AM
                              • lapfix
                                HP OMEN NO power no light
                                by lapfix
                                HP OMEN : DAG35DMBAD0
                                NO power ,no short ,no corrusion
                                Consumption : when charger plg in = 0.004 amp
                                Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                No light at power button led
                                All coils resistances :
                                Pl 2001 =3v measured with kohm.
                                pl 2004 = 5v measured with kohm
                                pl 6001 = 49.7ohm
                                pl 4012 = vccsa = 24.4 ohm
                                pl 3001 =...
                                11-03-2025, 07:48 AM
