FSP 400-60HLN rebuild
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    Since I still have the "leftover" FSP350-HLC I decided to beef up a 400-60HLN psu a bit... sort of.
    Cables are extremely short compared to the 60HLC, othervise it's decent. Based on FSP's green line series... most of you are very familiar with it.
    So internally the two psu are compatible. I'm going to swap some componets and see what happens. The psu works so far.
    I'm going to need some help with the pfc circuit. The 60HLN's booster coil is hanging by a thread and has a tiny dub of resin to hold it together, great. At least it's not fried. It also has a different core material from 350-60HLC coil, which is busted anyway so this one is way better.
    I added another 9n50c fet and a missing 10ohm resistor. I swear my soldering isn't that bad as it seems on the picture! I hope this second fet will not mess up the current pfc setup.
    To my suprise the primary capacitor (TEAPO 270uf 400V) had low capacitance so I replaced it with a new 390uf EPCOS.
    This psu has Capxon and Ost secondary caps. Maybe I'll change a few but if they measure good they can stay. It's hard to find 8mm caps here anyway. I've sorted out the new cables, anyway they'll go in last.
    Sadly I have little time for this project now so I continue next week.
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    Re: FSP 400-60HLN rebuild
    It's done. I guess the new components give a little more headroom for this unit without cramping it's functionality. Hopefully the ps223 won't die anytime soon, I've been told that it sometimes just craps itself and that's that. The 3.3 Volt line is a but high without load...
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      That's still within spec, oughta do fine.
      A working TV? How boring!
      • chth96
        How can I test coil whether it is really broken or not?
        by chth96
        I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
        I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
        I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
        I want to replace this round black fuse and unidentified coil if it got broken.
        02-20-2024, 01:07 AM
      • waterchill
        What part is this coil from a MacBook A2681 ?
        by waterchill
        Hi everyone
        I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
        So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
        IAny ideas? It is from a MacBook A2681
        Thank you...
        08-08-2024, 01:46 AM
      • Gjackson
        ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
        by Gjackson
        Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
        01-13-2024, 10:34 AM
      • chth96
        How Can I identify IFT coil?
        by chth96
        I have a CD unit which is came from saturn game console.
        It always perceived Any retail CD or CD-R as Audio-CD.
        Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
        I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
        I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
        Is there any way to identify its frequency in order...
        11-11-2022, 05:31 AM
      • lerom
        PowerEdge R740 coil resistance
        by lerom
        can anyone measure the resistance on coil L12 3.3V (near USB, EMMC chip) and coil L46 1V near CPU1 ?
        thanks....
        03-23-2025, 02:21 AM
