Caps in ac adaptor
  • VILE DISRUPTION
    • Jun 2006
    • 47
    Caps in ac adaptor
    i have a UNIDEN ac adaptor that outputs 3v 4.5v 6v 7.5v 9v and 12v dc. will the capacitors dielectric have broken down too much? (last use 1998 i think) or is it still useable.i havent been able to open the box to check the caps but i think they might have broken down. please help me as my kid would rather use it without any suprises.
    Stats Reset Every Month.
    My Forums
  • Rainbow
    • Aug 2005
    • 1375
    Re: Caps in ac adaptor
    It's probably not a switching one so the caps are not so much stressed and also not so much important.
    • VILE DISRUPTION
      • Jun 2006
      • 47
      yes well capacitors dielectric break down when they dont see voltage and this has been left for 8 years. just a little thought.
      My Forums
        by momaka
        03-12-2025, 03:42 PM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
