ENERMAX Liberty ELT500AWT
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: ENERMAX Liberty ELT500AWT
    Originally posted by Behemot
    I took some too, but I have run out of everything. I'd take from this guy if he could provide some reasonable price for say 100 pcs/16 V and 130 pcs/10 V.
    Usually it works fine with bigger cap before and smaller after, but there definitelly should be some capacitance on both sides of the coil…
    I personally have no problem with China, most of interesting stuff comes from there anyway They make everything there so they can sometimes get it and sell individually for good money
    Actually, the more I look at this board, I think I can just go with a fatter cap, if I raise it up. I seem to have 50mm of clearance and then some before it hits the fan. I would of course shift it over to where the wiring is and insulate the leads with heatshrink so it doesn't come in contact with coils surrounding it.
    SO what would I need panny FR? I would like to use Nichi HE because of how cheap they are on digi key.
    • mockingbird
      • Dec 2008
      • 5488
      Do you know what diameter of shrink tube are suitable for cap leads?
      • Behemot
        • 4845
        • CZ
        Digi-key states mounting holes distance for caps, have a look
        • mockingbird
          • Dec 2008
          • 5488
          Ah, you're going to use one piece of wide heatshrink for both leads? I was refering to the individual leads, as I have seen it on other caps... Reason I ask is I want to order an assortment of shrink tube but I'm not sure exacty which diameters are commonly used for various applications. Up till now I have been "bodging" with the black tape.
          • Behemot
            • 4845
            • CZ
            I think the wire is less than 1 mm so something under 2 mm should be fine. Can't say exactly, I have only plastic caliper which is useless for such small things
            • mariushm
              • May 2011
              • 3799
              #26
              The leads of most capacitors are up to about 1-1.5mm in diameter (I see for example in a datasheet 0.05" which I think is 1.27mm)
              You should be fine with some heatshrink tube with the internal diameter up to about 3-4 mm. May need larger if you want to use it for example on power supply wires diameters.
              What to buy... it all depends on the shrink ratio, most are 2:1 or 3:1 ...if the capacitor has leads that are 1.25mm (0.05") and you buy 2.5mm tube with a 2:1 ratio, there may still be some room between tube and leads.
              If it's 3:1 ratio, the tube will be really shrinked around the lead
              When I last ordered tube for me, I bought these two because I was too lazy to do the math and get the perfect fit:
              http://uk.farnell.com/jsp/search/pro...sp?SKU=1190979
              http://uk.farnell.com/jsp/search/pro...sp?SKU=1190935
              The black one is too thin for atx psu cables but just right for capacitor leads.. after shrinking you'd still be able to pull it off the leads, but otherwise it stays in place.
              The green one is quite large even for power supply wires but when shrunk it's quite ok for wires.
              • Behemot
                • 4845
                • CZ
                #27
                Originally posted by mockingbird
                I'm glad I bought some quantity from him back then. You're right, $2 a piece after shipping from this guy, but 4 is more than eough for this PSU.
                I am idiot. I jsut realized it was 0,6 EUROcents Capking has Samxons for 0,9 USD, that's not bad actually but I need some for 16 V too, he has for 10 V only.
                • mockingbird
                  • Dec 2008
                  • 5488
                  #28
                  Try to get 10mm Teapo SC instead... I rarely see the larger value ones bloat though admittedly I haven't the means to actually test them. I have FSP PSUs out in the field with them that are still alive and kicking after many years.
                  • Behemot
                    • 4845
                    • CZ
                    #29
                    Teapo…how can you even say that? U on BAD_CAPS here
                      I have seen enough Teapo fail to consider them mediocre, at best. I would not use them for a re-cap, but would probably keep existing Teapos.
                      • Behemot
                        • 4845
                        • CZ
                        #31
                        You are getting weak guys I change them on sight…
                        • c_hegge
                          • Sep 2009
                          • 5219
                          +1
                          So do I
                          • Behemot
                            • 4845
                            • CZ
                            #33
                            Just had a chat on Digi-Key. They didn't helped me much, but…well, if I will succeed in getting part number for any of the caps I want, I may get them order it from manufacturer
                            So, here is the deal. I don't know as you, but I would be interested in 3300 uF 10 V/16 V D10 caaps of these lines: NCC KY, Panasonic FC, Nichicon HE or Rubycon YXG/YXH. I will try to contact the manufacturers directly and get some infos from them…
                            • mariushm
                              • May 2011
                              • 3799
                              #34
                              If you're interested, I can mail you some NCC KZE 3300uF/16v (12.5x35) ...
                              I should still have about 20 pcs in my box of parts from my last Digikey order. That would be about 3-4 months ago, but I keep all my capacitors in sealed plastic bags, in a box, normal temperature and all that, so no need to worry about their condition.
                              1.15$ a piece, about 3$ in postage and packaging.
                              http://www.digikey.com/product-detai...1670-ND/756186
                              http://uk.farnell.com/united-chemi-c...16v/dp/1688903
                              I also had some Panasonic FM but last time I only ordered about 10 pcs so now I should have about 4-5 pcs left, and the price I bought them at sucks, about $1.5 each.
                              Anyway, with both of these you have to pay attention at the diameter (they're 12.5 in diameter, some if not most power supplies only reserve 10mm in diameter for these capacitors)
                              • Behemot
                                • 4845
                                • CZ
                                #35
                                I think I have clearly stated I want D10, right
                                There is plenty of D12,5 caps everywhere, but D10, thats the deal
                                • mariushm
                                  • May 2011
                                  • 3799
                                  #36
                                  Oh, I didn't notice that D10 there, and I was also confused a bit because KY is also only 12.5mm.
                                  I feel your pain about too few capacitors in D10 form at such high capacity values.
                                  • mockingbird
                                    • Dec 2008
                                    • 5488
                                    #37
                                    I wonder if UCC would do a custom KZx or KY series production run of these caps in 10mm...
                                    Otherwise, there is no other series with these caps other than Teapo SC in 10mm.
                                    • Mad_Professor
                                      A Mech Warrior
                                      • Feb 2011
                                      • 1587
                                      #38
                                      I'm thinking of getting this to replace the 16v caps, then ordering the RS from topcat.
                                      http://www.digikey.com/product-detai...1536-ND/589277
                                      It's a tad bit fatter, but if I raise it up and throw some heat-shrink on it, I think it will be ok.
                                      I also got a FSP psu with 16v capxon KF D10 H35 cap. It's a bit more forgiving on space though, so I shouldn't have a problem fitting it in there.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #39
                                        Sorry to polute this further, but when we started As for 6,3V D10 caps, I have just been informed through one of NCC's distributors there are new very nice lines on market, the KYA and LZA. Both have 3300 uF/6,3 V caps in D10x25 mm casing!! More or less same specs as Samxon RS while the KYA having even better lifetime.
                                        I will try to push through somebody to have them made in D10x30 (or even D10x35 is fine I think) for 16 V
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          Panny FK also has a 6.3V 3300uF (and 16V 2200uF) in 10mm dia. I often use them on 5v and 3.3v rails where I can't squeeze a 12.5mm cap in.
