Zalman ZM600-HP don´t start
  • Tioleco
    • Apr 2010
    • 46
    • Brazil
    I'm with a Zalman ZM600-HP that does not start.
    Fuse, NTC and +5VSB good.
    No signs of short.
    Fault in control circuit? (CM6800 - ).
    I have not found the schematic.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Zalman ZM600-HP don´t start
    This might help if you cant find a schematic.
    http://www.hardwaresecrets.com/artic...y-Review/402/1
    What voltage do you get on the Big Cap - Care HIGH voltage
    Please can you update your profile with country and mains voltage
    • retiredcaps
      • Apr 2010
      • 9271
      Edit: (now that I'm actually awake and brain functional)
      If this has PFC, then the voltage across the large cap could be 400V DC as selldoor cautions.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        edit:
        1) What is the DC voltage on pin 13 (VCC) with respect to GND (pin 10)?
        2) See if pin 13 and pin 10, above, are shorted with respect to each other.
        • Tioleco
          • Apr 2010
          • 46
          • Brazil
          this might help if you cant find a schematic.
          http://www.hardwaresecrets.com/artic...y-review/402/1
          what voltage do you get on the big cap - care high voltage
          please can you update your profile with country and mains voltage
          220vac = 310vdc
          • retiredcaps
            • Apr 2010
            • 9271
            220vac = 310vdc
            As I mentioned in post #3, if your power supply has a PFC circuit and is functioning, the DC voltage across the large cap should be close to 400V DC.
            • Tioleco
              • Apr 2010
              • 46
              • Brazil
              I found a shorted diode MBR3045 in the secondary , +12V rail.
              Thanks for the help.
              • прямо
                Viper22A 5VSB circuit
                by прямо
                So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                01-13-2024, 07:05 PM
              • kotel studios
                FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                by kotel studios
                Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                Any ideas where to go next?
                02-23-2025, 11:47 AM
              • socketa
                Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                by socketa
                Rescued this one
                Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                The 5VSB drops to 2.5V when it 'shuts down'
                And the voltage across the primary cap falls from 335V to 330V at the same moment
                I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                12-20-2022, 03:06 AM
              • mrcliem
                CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                by mrcliem
                Hello...
                I got my self a dead CM V700 PSU, with nothing on +5vsb
                I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                I have read the datasheet and and still can not...
                06-29-2023, 08:18 AM
              • davidk35
                Lenovo ThinkBook 15 G2 ITL, some little signs of life
                by davidk35
                So i got above mentioned laptop. Which shows only some little signs of life.
                When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                What ive already done:
                -Flashed both bios chips 16 and 8 mb.
                -Tried adding another stick of ram
                -Check if backlight is faulty.
                So any ideas?
                Thank you
                09-03-2025, 06:34 AM
