Dell PA-10 problems
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Dell PA-10 problems
    I got this Dell PA-10 that wont work, when I plug in the ac cable the green light works for about 10 seconds and then slowly turns off without plugging it in to the laptop.
    I thought the output caps was defect and changed them but same thing happend, even changed the startup cap - no change.
    Measured the caps
    kze 820uF 25V measures 824 0.04
    taicon HD 470 uF 25V measures 433 0.09
    ltec TH 10uF 50V measures 10 10
    Soldered off the gnd and + cable too see if the cable had a short, no change.
    Could not measure a short circuit in the cable.
    I did leave the id signal connected when I did this.
    Why would the powersupply behave like this ?
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Dell PA-10 problems
    That Ltec TH 10u's ESR is a tad on the high side. No ESR mentioned in the datasheet (general-purpose 105c series), just a 45mA@120Hz ripple rating, but 10ohms is... just wrong
    I also see two other small caps, right next to the main filter cap, have you checked (and/or replaced) those, as well? I don't see the white RTV-rubber disturbed yet
    I've got a hunch that Ltec is "just" the Vcc filter cap for the PFC controller chip, and those other two "belong" to the main PWM chip (one of those being the ACTUAL "start-up cap" )
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • selldoor
      Slow Learner
      • 7870
      Hi - could be a failing BIG cap? what voltage do you get across the legs? CARE high voltage. Can you do a better picture of the back of the board without flash. Good light is the key - try outside in daylight?
      EDIT
      Looking at te big cap again the covering is pulled away at the bottom did you do that?
      If not I would wear eye protection when testing it.
        This supply uses PFC too so it will have a separate cap for that.
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          Thanks for the tips guys. Was not aware of the PFC startup cap location.
          I did remove the two Ltec small caps near the KMG and sure they both did not measure anything with the RusMike's tool.
          Fitted Nichicon PJ and a Taicon is their place and now it is working.
          Also removed the Ltech that measured 10ohm and fitted a PJ there too.
          • selldoor
            Slow Learner
            • 7870
            Good fix, well done, I have a few of these so now I'll know what to look for if they pack in.
              Great to hear you fixed it, seems Ltec aren't even good as startup caps!!
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Caimano
                Problems extracting from Dell Bios Update.Inspiron 3793
                by Caimano
                I am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
                The board is FDI45-LAJ091P REV 1.0 A00
                Processor i7 1065G7 with GPU
                This MB has 2 Bios Chips (one 8MB and one 16MB chip).
                I am trying to reload a new Bios with clean ME region, new main region and new EC region.
                I attach the dumps of the 2 chips.
                I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions....
                05-04-2022, 11:19 AM
              • stakrzysiu
                Dell Vostro 15 5501 BIOS Problems
                by stakrzysiu
                i have here a Dell Vostro 15 5501
                REG Model: P102F
                SN: 1WD5103
                there is a problem that it shows screen after 1 min.
                Is this caused by me?
                Can someone clean me for me? Then i will try.
                Thank you very much
                Best regards...
                01-25-2025, 05:36 AM
                Dell Thunderbolt Firmware
                by SMDFlea
                Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                The SKU is in brackets (****)
                EDIT: NVM65...
                01-26-2025, 06:22 AM
              • dell_sadness
                Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                by dell_sadness
                BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                Have extracted the BIN and want to know how to rebuild a clean BIOS
                I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                11-12-2025, 02:54 PM
