I'm trying to power a Pentium 4 2.0GHz, an IDE SSD, and 1GB of RAM, from a car's 12V power thing.
Now, I could do this the retarded and inefficient and stupid way, using an inverter (also, I would have to re-cap and replace the fan in the SFF PSU if I wanted to do it this way), or I could do it right and just power it directly from the 12V.
I don't have a lot of space to work with, to build it. And it also has to have a 12V out port where I can plug in my 8" touch LCD (right now I'm powering this using a Netgear 12V 1A wall power adapter but that wouldn't work in a car)...
I've got the space in the CWT-220FXC power suply. My case is a small form factor case that holds the motherboard from https://www.badcaps.net/forum/showthread.php?t=21651
I assume I need to generate +12V, +5V, +3.3V, -12V, -5V, +5VSB for the 20-pin connector, 12V and 5V for the SSD, and 12V for the 4-pin CPU power connector.
If anybody has a method to this please let me know
Thanks!
Case: (i've removed all plastic to save space and make cooling better): http://www.dansdata.com/images/minipc/s868520.jpg
PSU: http://www.ixbt.com/mainboard/images.../xp4-g-psu.jpg (bad Fujyyu caps and bad fan)
