Antec Basiq 500w (BP-500U w/ pfc) Blown fuse
  • commercialcrocodile
    • Jul 2012
    Hello all, i've just signed up to this forum to ask a question about a psu that i just blew.
    While assembling a new computer build i was unable to find my anit static wrist band so i made the mistake of rigging up a makeshift one because i was sick of having to go over to where i had a powersupply to touch it to discharge. This was done by clipping an aligator clip to the outside case of the psu and attaching the other end to my wrist with an elastic.. i had a look inside the grate where i clipped it to make sure there were no components the clip could acidently touch and seeing only a heatsink i thought this would be fine, there was enough clearence anyway. Having checked earlier that this psu was off, i foolishly didnt re-check this.
    Anyway at some stage i moved a bit further than the alligator clip cord would allow and the tug on the cord caused the clips teeth to slip and it made contact with the heatsink. I heard a pop, and when i looked over there was a bit of smoke from where the arc had burnt a hole in the heatsink 1 or2mm deep. Very Fortunately for me the current would have run from the heatsink to the alligator clip then back to earth via the outside case of the psu, instead of up the wire into me! i perhaps owe my life to path of least resistance! this is certainly not a mistake i will be making again.
    Upon inspection of inside of the psu i was unable to see anything abnormal at all (bar the burnt in dent on the heatsink!) that is, no buldgeing caps, no burnt coils or any other burn marks of any kind etc. having finally found the fuse (sneaky thing was wrapped up and hidden away) i managed to cut off the plastic wrap and seeing as it is ceramic tested it with a multimeter (continuity at least, multimeter on the fritz. it just counts upward when on Ohms) and found there is no continuity. this is while it is still attached mind you.
    Having browsed this forum ive answered my first question which was "is it normal for the heatsink to be electrified" and i see now that primary heatsinks often are, something i will remember for the future. However, i was a little concerend with how little clearence there is between this heatsink and some parts of the case considering its design (3 sides removable cover, slots over but only has screws on the top. so the 2 sides have a bit of 'give' in them.)
    anyway, my real question is, considering the events that i have described, is it likely that any other parts of this psu could have been damaged in a non visible way. or seeing that the current went really straight back into the case and to ground would this avoid damage to the psu (and also to the motherboard that it was plugged into... yes yes i know. incredibly foolish of me) from my above average-joe but still very much basic understanding of electronics my feeling is that the motherboard etc will be ok. however im not sure about the components that lie in betweent the fuse and the heatsink that shorted with the case. what other components are involved in the over current protection? im not sure if the IC that controls some of the other protections does that aswell. if the IC does the OC aswell, would it likely to be damaged? normally it would just switch off wouldnt it? or are the IC controlled protections only for the outputs and not intended for this kind of short. I presume these would have assisted in protecting the motherboard. it wasnt switched on just in standby. thats what i get for not re checking that things are off. I am currently looking up how to test some of the other components in the psu
    so really im hoping that if i replace this fuse i will be able to salvage this psu. from what i have read most people seem to agree that replacing this fuse with a glass instead of ceramic will be ok, but i will try to get a ceramic. if memory serves it was either a T6.3A 250v or T8A. both were listed for different wattage psu, of course i will confirm this before switching it.
    unfortunately its the type with the end caps and wires and soldered onto the board and it really is in quite an awkward location, so before undertaking this task and possibly just making things worse i thought i would ask for some opinions from you all here who know much better than i.
    sorry for the long post, just trying to include as much detail as possible. any advice would be much appreciated. thankyou, James.
    p.s if photos would help i can provide these as soon as i get a chance.
  • RJARRRPCGP
    • Jul 2004
    • 6301
    Re: Antec Basiq 500w (BP-500U w/ pfc) Blown fuse
    I believe the heatsink is live with mains power and primary DC.
    Probably blew the primary.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      A lot of people seem to think that an antistatic strap should be grounded with zero ohms. This is wrong - you must use a high resistance of around 750k to 10 megohms. A common value is 1 megohm.
      I'm pretty sure the only thing that would have been damaged is the fuse. Replace it and it should be okay.
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • piernov
        Core 2 "gaming" build with SLI
        by piernov
        My turn to post a build I guess, wasted way too much time on this one…
        First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
        Everything done with random parts I had lying around.
        Specs :
        • CPU: Core 2 Quad Q9450
        • RAM: 2x2GB KHX6400D2K2
        • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
        • MB: P5N-E SLI
        • PSU: Antec Basiq Power 550 Plus
        • HDD: Hitachi Ultrastar A7K2000 1TB
        • ODDs: DVD ROM, DVD RW
        • Case: not sure
        Cooling:
        • 92mm rear fan
        • 120mm front fan
        • Additional heatsink on southbridge
        05-20-2023, 11:38 AM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
      • harp
        Metod for removing glued heatsink from fragile component
        by harp
        I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
        06-23-2025, 02:01 PM
      • jshhh
        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
        by jshhh
        Hi guys,
        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
        Anybody know how to remove this type of fuse?
        (The fuse is toward the bottom of the image labeled F2)...
        06-17-2025, 01:35 AM
