Re: HP-D3057F3H recap
I'm surprised Newton Power PSUs have worse voltage regulation given how well designed they are otherwise. But I do concede that the Newton Powers I've seen have better fans (usually better than ADDA) and choice of capacitors (the worst I've seen in my Newtons is Ltec - the worst I've seen in a Hipro is well, Arkon) Hipros do of that era, so them's the breaks I suppose. However, assuming these tests are correct, this Hipro does not seem to have such great voltage regulation (unless it has something to do with only having 9A on the +12V rail and being rated at 300W).
I had a HP-P2507F3P as well in a Dell Dimension 8200, though revision H01, whereas if I'm not mistaken (as shown in the PSU build thread) yours is H01A. But as I've stated, the fan in mine is starting to lose its lubricant so it's starting to die, and because my PSU does not have screws for the fan, I'm not sure how to remove it. I do know it's a 80x80x20 sleeve bearing fan from ADDA, and my guess it's high speed because of that (3010RPM/27.3CFM/.128" air pressure from the datasheet if I'm not mistaken). Probably was not doing the job it could have done though because Dell, in their infinite wisdom, decided to put an extra grate on the back of their case, right in front of where the PSU exhaust intake is. That may be better for dust as Dell stresses they do not like dust in their documentation, but I don't know how that impacts the cooling of the PSU. But given that the PSU has a Passive PFC it's already running a bit warmer anyway. Anyway, my version had a mix of Teapo (on the primary, 680uF/200V at 85C, and secondary), G-luxon, and Asiacon capacitors, rather than Panasonic (560uF/200V at 85C)/Asiacon. I don't know if that's any better or worse than all Asiacon on the secondary but I do know it never gave me instability problems. I don't know how stable the voltage regulation was because I only ever used that PSU in a Dell Dimension 8200 and Dell do not give you temperature sensors, much less voltage readings (though the ones of the motherboard sensors aren't accurate anyway). And I never measured it myself. But I'm guessing it was darn stable if yours was.
Bestec PSUs are good save by the brown glue Bestec likes to add and their choice of capacitors, and save for lack of OPP (OTP would be nice too but you don't see that in too many PSUs.... preferably, a PSU should INSTANTLY shut down when it detects the fan is no longer running, if it does, but I don't know of any PSU with that ability). Maybe recapped, they have better voltage regulation, unless you already recapped the ones you reference.
Looks are deceiving, then - I suppose even if it looks desolate (though it may not be missing any components) that the quality of the components matter even more than the amount of them. I wonder if half bridge topology is that bad of a thing, considering I always see PSU reviewers scorn PSUs for having that instead of full bridge, single transistor forward, or whatever else.
) and the 5V and 12V rail were doing much better.
