HP-D3057F3H recap
  • Shocker
    Banned
    • Dec 2011
    • 635
    HP-D3057F3H recap
    I did this earlier today using capacitors from old motherboards. I'm glad I didn't wait longer to do it. Even so, I should have done it much earlier. You'll eventually find out why...
    Original capacitors (all are 10mm except the +5VSB):
    • +3.3V: LTEC LZP 2200uF 10V
    • +5V: LTEC LZP 2200uF 10V
    • +12V: Chemi-con KZE 2200uF 16V
    • -12V: Chemi-con KZE 2200uF 16V
    • +5VSB: Teapo SC 1000uF (bulged) and 470uF 10V
    Replacement capacitors:
    • +3.3V: Nichicon HM 3300uF 6.3V
    • +5V: Nichicon HM 3300uF 6.3V
    • +12V: Not replaced
    • -12V: Not replaced
    • +5VSB: Rubycon MBZ 1000uF 6.3V
    I also replaced the primary caps (Teapo LH 680uF 250V) with Chemi-con SMQ (same value and voltage). Best to be on the safe side.
    I was originally keeping it on the list of spare PSUs to be (eventually) recapped. Only today did I discover that the repair was overdue.
    I went to install the fixed PSU in my PC. I pulled another (unrepaired) unit out of my PC. I waited long enough for one of the +3.3V caps in that one to go from non-bulging to leaking. (In case you're wondering, the +5VSB caps in that one weren't bulging.)
    The only symptom of that crap was a faint high-frequency whine.
    Morals of the story:
    • Even totally busted caps don't always show obvious symptoms.
    • NEVER leave crap caps alone.
    • Never, EVER use an HP-D3057F3H with the original caps.
    Any comments???
  • c_hegge
    • Sep 2009
    • 5219
    Re: HP-D3057F3H recap
    I've recapped about 20 of those in the past. Usually, the 1000uF teapo on the 5vsb fails, and the PSU won't start. They are good PSUs, though, after a recap.
    • Shocker
      Banned
      • Dec 2011
      • 635
      I would have used closer caps to the originals if I had some
      But the MBZ were the only quality 1000uF 8mm I had, and while I had a third Hipro to take parts from (which was where I got the Chemi-con primaries), I chose to save the 2200uF 16V KZEs for something that actually needs 2200uF 16V 10mm caps.
      Anyway, it works, and that's what matters.
      • mockingbird
        • Dec 2008
        • 5484
        I am curious how much ripple is coming out of your +5VSB line with that MBZ in there...
        • c_hegge
          • Sep 2009
          • 5219
          I doubt it would be much. I polymodded one once, and used a 6.3v 1000uF Nichicon L8 in that position. I got exactly 2.0mV from the 5vsb with 1A Load. My main concern is actually where they came from. If he scavenged them from the VRM low side of a motherboard, then they will have de-rated to 1.5V or so.
          • Shocker
            Banned
            • Dec 2011
            • 635
            I don't have an oscilloscope.
            Neither the 1000uF MBZ nor the 3300uF HM were from Vcore.
            • c_hegge
              • Sep 2009
              • 5219
              They might be OK then.
              • Shocker
                Banned
                • Dec 2011
                • 635
                Actually what I'm worried about, if but slightly, is this:
                https://www.badcaps.net/forum/showthread.php?t=19391
                  master hoarder
                  • May 2008
                  • 12170
                  Should be less.
                  The 5VSB power supply, unlike the main power supply, doesn't have large chokes and the control loop is slightly different, so such circuits actually benefit from the lower ESR caps.
                  In the main power supply circuit, the output capacitor-inductor filter is tuned, so deviating from the ESR of the caps that were originally used actually increases the ripple.
                  • Shocker
                    Banned
                    • Dec 2011
                    • 635
                    Take a look at the poly-mod on HWI, and note how the Hipro was the only PSU to work properly after the mod (the SmartPower worked fine on the load tester but failed in-PC, while the NeoHE went crazy). Surely if it can cope with polys then MBZ and HM can't be a problem.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Precisely what I was thinking.
                      • Shocker
                        Banned
                        • Dec 2011
                        • 635
                        By the way...is that an MBZ I see there???
                        And I was wrong about the source of the whine. There are actually two different whine sources. The first one I think is the CPU fan motor. The second is the monitor (maybe it has bad caps, I haven't checked).
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Yup. I had to recap it to get a baseline ripple reading, since the Teapos there had failed, and were preventing the PSU from starting
                          • Shocker
                            Banned
                            • Dec 2011
                            • 635
                            No, I think that one's wrong again.
                            But the monitor is still a source.
                            • Shocker
                              Banned
                              • Dec 2011
                              • 635
                              No wait, maybe I'm right again.
                              I think the fan motor whine peaks around 2000RPM.
                                master hoarder
                                • May 2008
                                • 12170
                                I don't mean to denounce HWI, but IMO shovenose and c_hegge got lucky with the design on that HiPro. Most PC PSUs are NOT designed to use polymers or very low ESR caps. Like I mentioned, it often introduces ringing in the DC filters, which in turn results in more ripple and noise - *most* of the time.
                                Using polymers with half the capacity is even worse, because the response time of the control loop (the circuit that actually regulates the voltages and keeps them stable) is severely affected and may not be able to respond properly to the varying loads from the PC anymore. This is most likely the reason why that SmartPower didn't work in their PC.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  I agree with you, and I do think I got lucky that time. Generally, I've never advised poly-modding power supplies, but this one just happens to be tolerant.
                                  • Shocker
                                    Banned
                                    • Dec 2011
                                    • 635
                                    I added a new NMB dual ball bearing fan and Panasonic ED 105°C primary capacitors. Because I want my stuff to last as long as possible.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Those SuperRed fans that they come with are actually pretty reliable. I sometimes add a drop of lubricant to the bearings just to be sure, but I've never had one fail before.
                                      Believe it or not, I just came accross one which had the usual bad Teapo 1000uF on the 5vsb which was preventing it from starting, but the other caps were Chemi-con KZE on the 12V rail and Nichicon HM (Equivilant to Ruby MBZ/Panny FJ/Sanyo WG) on the 5V rail. It also had Chemi-con primaries. I recapped the 5vsb with a Chemi-con KY for the failed 1000uF teapo, and a panny FM for the 470uF. I used Ruby MBZ for the 3.3V rail (which had Teapos originally). If Hipro are using Nich HM or equivilent, then these PSUs must be fairly tolerant of lower ESR caps.
                                      I realise that the capacitance shouldn't be halved in PSUs, but 3300uF 16V polies simply don't exist, so I used the closest I could get my hands on for the experiment.
                                      • Shocker
                                        Banned
                                        • Dec 2011
                                        • 635
                                        I know. It's just that I never feel 100% confident about sleeve bearing fans, regardless of manufacturer.
                                        I also recently got my hands on a HP-D3537F3H. The caps are:
                                        • +3.3V: 1 x 10mm Chemi-con KZE (couldn't read value) and 1 x 1000uF 10V 8mm Teapo SC (popped; the silkscreen is for a 10mm)
                                        • +5V: 2 x 2200uF 10V 10mm LTEC LZP (same as the older model)
                                        • +12V: 2 x 2200uF 16V 10mm Teapo SC (same as the older model)
                                        • -12V: 1 x 1000uF 16V 10mm and 1 x 470uF 16V 8mm Teapo SC
                                        • +5VSB: 1 x 1000uF 10V 8mm (popped ) and 1 x 470uF 10V 8mm Teapo SC (same as the older model)
                                        This is a more 12V heavy unit, as opposed to the HP-D3057F3H. At least according to the label.
                                        • +3.3V 15A
                                        • +5V 13A
                                        • +12Va 18A
                                        • +12Vb 18A
                                        The combined +12V rating is 25A. Unfortunately I couldn't find a combined +3.3V and +5V rating on the label. The fan is an ADDA .
                                        The +12V has two MBR20H100CTGs. The +5V has two SBL2060CTs. There are two rectifiers on the +3.3V but I couldn't read their markings.
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • kotel studios
                                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                          by kotel studios
                                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                          Any ideas where to go next?
                                          02-23-2025, 11:47 AM
                                        • mrcliem
                                          CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                          by mrcliem
                                          Hello...
                                          I got my self a dead CM V700 PSU, with nothing on +5vsb
                                          I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                          As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                          The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                          I have read the datasheet and and still can not...
                                          06-29-2023, 08:18 AM
                                          BFG Tech BFGR550WGSPSU [LW6550SE Rev. K] – recapping & modding
                                          by momaka
                                          Rather than post in the PSU build quality pictorial thread, again I am splitting off the recapping info into its own thread. Also, I plan on doing some possible modding/experimentation on this PSU, so I figured that info would also be better to go here.
                                          The PSU in question is this one:
                                          Detailed post with parts and build quality is here:
                                          https://www.badcaps.net/forum/showpo...postcount=3085
                                          So this PSU has very simple output filtering: two 2200 uF caps on each major rail (3.3V, 5V, and 12V.)
                                          Here is a cap diagram showing the caps...
                                          06-13-2020, 12:41 PM
                                          no-name Radeon 9600 XT recap and cooler
                                          by momaka
                                          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                          This one was actually suggested to me by ChaosLegionnaire....
                                          11-06-2020, 07:54 PM
