iMAC G5 ALS PowerSupply identify resistor value
  • n1007
    • May 2012
    • usa
    Hi all
    > I got iMAC G5 ALS PowerSupply API4PC46-290 03L66
    > I need to know resistor R89 value (it look very bad) it is next to on/off Wire and HS3.
    > Can someone find it out ?
    > Thank!
  • Toasty
    • Jul 2007
    • 4171
    Re: iMAC G5 ALS PowerSupply identify resistor value
    Have a picture of the area?
    veritas odium parit
    • n1007
      • May 2012
      • usa
      I just bought a new one.
      Thank for help
      • Toasty
        • Jul 2007
        • 4171
        Useless thread...
        veritas odium parit
        • gica69
          Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
          by gica69
          I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
          Resistor shows orange range silver gold and green lines.
          Thanks in adv...
          07-21-2025, 09:49 PM
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • robyb
          help identify Imac transformer
          by robyb
          i managed to break off a transformer from my Imac a1418 logic board when i was mounting it back.
          it's this one and i cannot identify it so i can order a new one.
          Also it would help if someone can tell me if it could be the reason why my Imac will not start.
          The green led is "on " on the motherboard , but when i hit " power on" nothing happens.
          i will attach the schematics here.
          11-16-2022, 04:17 AM
        • sikocan
          Identify resistor R802 PS4 Pro PSU
          by sikocan
          Hi team, can you help identify value of this resistor. From a PS4 Pro. PCB board model: N300A004L. Location of resistor is R802 as pictured....
          11-01-2022, 07:33 PM
