Konica DR-BC-K4 Battery Charger
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Konica DR-BC-K4 Battery Charger
    Originally posted by starfury1
    That "mosfet" on the secondary side of things is from what I can work out a PNP transistor type number HT772
    From the pdf I grabbed its use's are output for 1Watt audio amp ,Votage regulator, DC DC converter, Relay driver.
    package type TO 126
    (I really should have known the package type but couldn't recall it at the time I did the reply above...brain getting old and rusty LOL)
    Pin out from you pic above is (L2R) Emitter Collector Base
    (looking at the numbers on the back)
    Interesting, I never even found the PDF, I guess your google skillz are beyond mine Yoda
    D2 appears to be a high speed rectifier diode and along with that 16 Volt cap would be the AC secondary to secondary DC (rec, filter part of the circuit)
    (half wave by the looks of it) You say you have no DC there
    I'll stand to be corrected on this thought.
    I said I have almost no DC voltage here, but it slowly climbs up to about 0.7v, after a minute or so...
    Next a question you say the DH565 gets really hot, is the transformer or any other components getting really hot? Err make sure you unplug it OK.
    If its not doing any work I would expect nothing to be getting overly hot
    I measured it plugged in, it is only the DH565 that gets hot, the transformer is at 30°C or so... The rest of the components are cool to the touch...
    I dont know how likely it is for the DH565 to fail internally but if static tests of components are not showing up a dud then possibly it is the fault
    Again I know its not the answer your looking for but hope it helps
    Your help is more than welcome, I've already spent too much of my own and others time on this so why not go to the bottom with it
    gonzo0815; ok, well, I was not expecting the caps to be a problem since they have seen so light use, but of course they are still from 2002 or so so it is very probable that they have dried out I guess...
    Don't have any that small 400v caps to swap it out with though, I guess it would not be so smart to connect a 600uF cap in it's place
    • gonzo0815
      • Feb 2006
      • 1600
      If you replace the fuse, the rectifier, etc. you can probably use that bugger ;-)
      But yes, i think some smaler would be better.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i would first check the output rectifier for a short then replace the dh565.
        could still have a shorted winding in the transformer bu that is rare.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          How do I test the rectifier(s)? (they are the D2 and BD1 chips on the underside of the PCB right?)
          • gonzo0815
            • Feb 2006
            • 1600
            Probably D2, ist is probably an shotky type e.g. sbl540 or similar.
            You can chek that with an diode or resistance cheker. The diode must led the current flow in only one direction, e.g if you reverse your test tips (and therefore the polarity) it must either let the curren flow or not. If you has no resistance in both directions, the thing is short.
            If it is open in both direction it is defective too.
            For replacement, you should use any suited shotky diode or some fast switching types.
            May be it is necessary to desolder one leg, if you got strange readings.
            @kc8adu
            why you consider those rectifier to be the faulth? is this a common problem in smps?
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              #26
              Bought a new charger, got it today in the mail. Hooked it up to 230VAC and put the battery in it; nothing, no "charge" LED blinking...
              Me thought this was a bit odd so tried the included power cable, same thing
              It also came with a separate 12-24VDC input, for use in cars, so I put it in my car and viola, charging like a sharm
              Now where is the irony in this, damn Murphy!
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                @kc8adu
                shorted schottky diodes are quite common in smps.they dont survive spikes and near lightning strikes too well.they are usually low voltage and often not much margin for overvoltage.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  #28
                  Haha, opened the sucker up to see if there was anything obviously wrong with it...
                  I wont even say a word, the pictures describes it best, though seeing a device that makes the "Deer" brand look über highend sure is a fitting description
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #29
                    I measure 320VDC up to the transformer on both chargers, and on the other side of both transformers I measure nothing... If I measure across the terminals on the output of the transformer I measure a short, is this normal/the way it should be?
                    I tried giving the old charger 12v DC on the secondary side of the transformer (behind a diode to not cause a short circuit) but the powersupply shut down (shortcircuit or overcurrent protection I guess)
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      #30
                      Probably there is no short, it is the transformer windign which normaly hasn`t that high resistance. it is the inductance which mathers there. So with normal DVM you read an short.
                      You should meassure the shotky as kc8adu stated.
                      I doubth that there is anything else wrong than evt. the shottky and the caps. At least the tiny smps isn`t that dificult to fix, and in my opinion it is very robust.
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                      • flat-earther
                        how to prevent a connected charger from draining battery when not charging?
                        by flat-earther
                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                        So the battery is backfeeding the charger and being drained.
                        How can I prevent...
                        08-07-2025, 01:04 PM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                        Bauer tool battery pack charging with a HERCULES charger modification
                        by sam_sam_sam
                        The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                        Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                        05-06-2023, 12:17 PM
                        Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                        by sam_sam_sam
                        I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                        So I have put them on the battery testing machine to drain each battery cell down to...
                        09-04-2022, 04:45 PM
