Switchmode salt water chlorinators?
  • japlytic
    • Oct 2005
    • 2086
    In a magazine, I found that salt water chlorinators had low voltage (around 12V), high power transformers. When I was looking for some, the largest I saw on a manufacturer's website was a 600VA unit.
    I am wondering if there are any switchmode units available (they would need some sort of corrosion protection!)
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Switchmode salt water chlorinators?
    Can you link some examples of that kind of applikation? For what purpose are this applikation?
    • japlytic
      • Oct 2005
      • 2086
      http://www.autochlor.com.au/commercial.asp - the largest swtichmode chlorinator (SMC-2000) was for a 4 megalitre pool, with a maximum output of 24V @ 420A (10kW!).
      The benefits of switchmode chlorinators when compared to conventional transformer models include electronic voltage control (via panel switches or an interface which changes the feedback circuit for a particular voltage) and better overload protection.
      More links for switchmode chlorinators:
      http://www.a2m.co.za/Html-en/equipme...rinator-en.htm
      http://www.electrochlorinators.com/waterTreatment.asp
      • gonzo0815
        • Feb 2006
        • 1600
        Intersting those units. But what do they do with the hydrogenium gass? i think for saftey and sustainability they shoulld burn it, not leting pass it out of the atmosphere.
        In any way, if those chambers are working with 12v, it is no problem do use some smps for that. For the lower power units it is obviously not a problem. For the higher wattage units there are pleanty of smps units capable of driving very high currents e.g. for battery charger for staplers or for the galvanizing industry.
          20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
          I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
          At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
          Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
          04-09-2023, 08:04 PM
        • Ugur87
          MacBook Air M4 A3240 Brand New Water Damage no Image
          by Ugur87
          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
          08-28-2025, 01:09 PM
        • RetroComputingGrotto
          Water Damaged Toshiba 48L1435DB
          by RetroComputingGrotto
          I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
          The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
          10-07-2024, 08:23 AM
        • edugimeno
          Stagg sms12p audio amp has water damage
          by edugimeno
          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
          There is only one signal wire connecting the first boards...
          05-24-2025, 06:00 AM
        • rzsn
          water damaged G513I
          by rzsn
          Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
          Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
          12-22-2024, 09:02 PM
