Fake primary capacitors
  • Pentium4
    replied
    Re: Fake primary capacitors
    Hahaha I am curious to know, they're probably 680's. And you should post some pics of the PowMax too!
    replied
    Originally posted by Pentium4
    Not surprised about the JEE caps, those things are trash!
    JEE, you think so?
    Sorry, I just couldn't resist a dumb name joke like that
    Although I have only seen them in ancient power supplies, think they went out of business?
    I hope so. Chances are, though, if they are not making JEE caps anymore, they're probably selling under a different brand. Or worse, making sleeveless generic caps and selling to random people/companies to put on their own brand.
    I'm going to pull out those JEE caps from my PowMax PSU and measure them on the capacitance meter in my friend's shop this week. Pretty sure the bulged one won't be in spec, but I wonder what the "good" one will show.
  • Pentium4
    replied
    Originally posted by momaka
    I'm guessing an old Leadman unit?? I saw pictures here on BCN of a fairly okay-built LP-6100D unit with supposedly original "Rubycon" primary capacitors. Makes me wonder if they were fake too. That PSU had some Rulycon caps on the secondary.
    I have an older 6100D too (a PowMax). Built quite well but has 1 bulging 200V 1000 uF JEE cap on the primary and several Jun Fu WG caps on the 3.3V and 5V outputs.
    It's not even a year old...Not surprised about the JEE caps, those things are trash! Although I have only seen them in ancient power supplies, think they went out of business?
    Originally posted by tom66
    It's amazing how widespread this problem is. I wonder why PSU manufacturers keep buying mislabelled capacitors.
    It is amazing...You'd think they would want to know what they are getting!
  • PeteS in CA
    replied
    Well, tom, P/S mfrs don't make or label the caps they use (AFAIK). Delta started as a mfr of magnetic components, and Liteon as a semis mfr, but I don't know of any P/S mfr that started as a caps mfr. P/S mfrs specify and buy caps, and sometimes the price they can sell at dictates component choices. That may mean choosing between using dubious quality components and and having to stop selling to parts of the P/S marketplace. Both strategies have longterm risks.
    All that said, the problem of fraudulently labelled caps is probably a fraud committed by the cap mfrs. They gave properly labelled parts in the design stage, and then started selling fraudulently labelled parts after prototyping and pilot production. Design, prototyping and pilot production is when testing is most stringent, and fraudulently labelled parts would be caught (by hold-up time or ride-through tests). Once in volume production, testing will likely be rudimentary (turned on, full load voltages, maybe min load voltages, maybe PARD). The P/S mfr should randomly and regularly subject samples off the production line to complete tests, but that takes time and disrupts/complicates the process slightly. And if they find a problem, what then? Line down? Recall product using the problem parts (Does the P/S mfr have records of what parts lots were used in what lots of P/Ss? Wanna buy a bridge?). So there's more than a bit of trust or willful blindness on the side of the P/S mfr. Unless there's a Dell-Nichicon-style disaster, no one will get hurt, except for the consumers whose computers were a bit flaky or lasted 2-4 years instead of until becoming hopelessly obsolescent.
  • Khron
    replied
    Do you even have to ask? (cheapness)
    replied
    replied
    Came out of a Leadman
  • Pentium4
    replied
    More! "technically" in spec but this was from a brand new PSU so I think they are fake once again...They feel pretty light even for 560
  • Khron
    replied
    ... And they're not snap-ins
  • ben7
    replied
    I posted this in the hall of shame but figured might as well add it to this thread as well. Came out of a Leadman
    Fake one LOL
    KMG sleeves are supposed to be brown not black xD
  • Pentium4
    replied
  • ben7
    replied
    They are still doing this. Cap was manufactured the first week of 2013.
    Get out the guns!
  • Pentium4
    replied
  • Heihachi_73
    replied
    That line through the side of the 'Mercedes' vent looks like they tried to turn it into a K shape to match what a Rubycon should have.
  • Pentium4
    replied
    Originally posted by ben7
    Notice the wacko vent shape on one of them!
    Yeah true! But they probably had plastic discs over them though?
    Originally posted by Heihachi_73
    The JEE 330uF 200V primaries which came out of this trashed King World ATX-250W PSU measured at 202.8uF and 198.8uF respectively, both with an ESR of 0.07 ohms and a date code of 9828. No doubt they are 220s with a 330uF label, as they are still in tolerance of said capacitance.
    Same again with Su'scon. The two 470uF 200V LXs I ripped from an L&C LC-230ATX were measured at 312.0uF and 319.9uF respectively; both 0.06 ohms ESR. As with the above caps, they are well within tolerance... of a 330uF capacitor. This PSU was also from 1998.
    Wow that's crazy, doesn't surprise me though from L&C
  • Heihachi_73
    replied
  • ben7
    replied
    Those are some decent looking fakes. Also curious to know their actual capacitance
  • Pentium4
    replied
  • ben7
    replied
    Originally posted by japlytic
    I found these fake Rubycon snap-in units in two identical Chinese power supplies.
    Officially, Rubycon USP only comes in 85C whereas these fakes (both USP series) were labelled 105C.
    Haha well found!
    Got any esr specs and capacitance specs for the fakes? (I.e., are they actually 100uF?)
  • japlytic
    replied
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
    by momaka
    03-12-2025, 03:42 PM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • Galraedia
    Fake Caps in Xbox 360
    by Galraedia
    I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
    02-04-2023, 09:55 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
