HP Power Brick
    master hoarder
    • May 2008
    • 12175
    #41
    Re: HP Power Brick
    Probably best idea to make a new thread about the laptop. That way we can still stay on track with this PSU.
    When you're done inserting the components, the blue circle test point should also have full continuity as well, just like the other test points. If that's the case, then just check the voltage on pin 2 of IC3 (the L6384D controller).
    • rigeback
      • Mar 2011
      • 421
      • Malta
      #42
      Re: HP Power Brick
      Well put it all back together including the cap I substituted since it looked ok and then I hooked it up to fused plug as I wasn't sure about my soldering skills and some of the heat shrink is missing totally on R15, anyway shocking as it seems I found the LED glowing and bingo 19V power out!! I'm thinking now that it's possible that there was a solder defect on R15 or C6, anyways will reassemble the brick and see if it holds out.
      One thing I would like to know since I have removed all that white bog is what product should I use to re-stabilize the components, I read some where that white silicon used in bathrooms is acceptable??
        master hoarder
        • May 2008
        • 12175
        #43
        Re: HP Power Brick
        No, you can leave everything the way it is. Manufacturers use that white glue to temporarily hold down components before they get wave-soldered. Once soldered, the glue is not needed, but since it doesn't usually harm anything, they leave it in there.
        As for using bathroom silicone - I think that won't work. Most types of silicone are slightly acidic and they can eat away components' leads and traces on the board, so don't use it.
        • rigeback
          • Mar 2011
          • 421
          • Malta
          #44
          Re: HP Power Brick
          Yes I assumed there was no houshold product to to replace the glue so I replaced all the parts without it, anyway its been working well for nearly a week now and the mobo was not damaged, lucky me!
          Thanks everyone for the support.
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
            03-31-2024, 02:12 PM
            09-06-2024, 05:59 AM
          • Gentian
            Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
            by Gentian
            I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
            09-27-2025, 11:03 PM
            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-12-2024, 02:15 PM
